Spark plug gaskets, Inside the cooling shroud or out? |
Elliot Cannon |
Sep 22 2009, 09:57 PM
If there is positive pressure inside the cooling shroud, wouldn't these seal better if they where pushed inside the cooling shroud? I've always installed them on the outside. Do you?
Lo-Fi Version | Time is now: 23rd May 2024 - 04:48 AM |
