| JmuRiz |
Sep 28 2009, 03:15 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,626 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region
I'm in the process of shopping for a lift.
The question of 2 or 4 post has come up. A 4-post will fulfill my needs (mostly storage and some work), but I'm not sure if a 914 and 356 motor can be dropped between the 32" gap in the middle. Any ideas/experiences on engine drops with a 4-post lift? Thanks. |
| Cap'n Krusty |
Sep 28 2009, 04:13 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
My guess is "no". The Cap'n
| Heeltoe914 |
Sep 28 2009, 04:16 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,135 Joined: 31-January 06 From: Tujunga Calif, Member No.: 5,506 |
No I have both and it would be easier on the floor. Some stuff like brakes, Oil changes and trans removal OK.
| Ferg |
Sep 28 2009, 05:49 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None
Depends on the brand on how the Skids move...
Yes on my Bend Pak, right skid "floats" and you can make it as wide as you would like. Position the car so that it's as wide as possible, (inside of tires just on the skids) and it's enough to clear the engine mount bar. |
| mskala |
Sep 28 2009, 06:11 PM
R ![]() ![]() ![]() Group: Members Posts: 1,944 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None
QUOTE Depends on the brand on how the Skids move... Yes on my Bend Pak, right skid "floats" and you can make it as wide as you would like. Position the car so that it's as wide as possible, (inside of tires just on the skids) and it's enough to clear the engine mount bar. I agree. I've been thinking about doing that this winter on my 4-post. Basically the ram is in one rail and the other rail is 'free'. You can drill 2 more holes on each end and move it quite some distance. |
| SLITS |
Sep 28 2009, 06:48 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
I drop engines all the time with the two poster (and not on the floor either).
| aircooledtechguy |
Sep 28 2009, 06:51 PM
The Aircooledtech Guy ![]() ![]() ![]() Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
I have a 2 post Rotary. I can only think of a couple occasions when a 4 post would have been better, but I forgot what they were (IMG:style_emoticons/default/biggrin.gif) My vote is for a 2 post. . .
| Gint |
Sep 28 2009, 08:42 PM
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,107 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
As Ferg said, it depends on the lift and whether or not the rails move.
A 4 post doesn't have to be bolted to the floor and can be moved with wheels that can be added and removed as necessary. They are also better for storage and additional parking use. 2 post and 4 post lifts each have their pros and cons. |
| PRS914-6 |
Sep 28 2009, 11:06 PM
Excellence Magazine Project 914 3.6 ![]() ![]() ![]() Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
Have you thought about avoiding a post lift altogether and saving shop space? Here was my solution My Lift
| Heeltoe914 |
Sep 28 2009, 11:14 PM
I'm in the process of shopping for a lift. The question of 2 or 4 post has come up. A 4-post will fulfill my needs (mostly storage and some work), but I'm not sure if a 914 and 356 motor can be dropped between the 32" gap in the middle. Any ideas/experiences on engine drops with a 4-post lift? Thanks. OK did I not read this correctly he has 32 inch to go between. I figured that he is limited between the 8 foot wide or the 8'9" wide four post? If you can get the motor out of a 914 with 32" I stand corrected. bottom line is if you really wont to save some time working on your car go with a two post. If I get some time I will take a pix of my 4 looking up at the eng. it may help you decide. Any lift is a good lift you can buy one more car. |
| Ferg |
Sep 29 2009, 10:38 AM
(IMG:style_emoticons/default/agree.gif) 2 post is best for actual "work"
But... my big hang up with the two post was slab issues. 2 posts require a 4 inch slab that is reinforced. I have yet to see a house that was built in the last 20 years that has a 4 inch garage slab, at least in this area. After checking mine out, it varied from 2.7 to 3.8 inches. My 4 post in anchored at each corner, 4 bolts, and for the weight of a 914 it's a non issue. For me to have put in a 2 post, it would have required cutting out sections of the floor, and a repour ect. Since the 4post I chose worked well for engine drops, the only thing I really lack, is the wheel off stuff... Ferg |
| URY914 |
Sep 29 2009, 10:42 AM
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 132,583 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Ferg,
You should have called me. We could have cut out a section of slab and poured back a nice foundation for a two post in a weekend. With a slab that thin we could have broken it up with a sledge hammer. |
| Ferg |
Sep 29 2009, 11:20 AM
Ferg, You should have called me. We could have cut out a section of slab and poured back a nice foundation for a two post in a weekend. With a slab that thin we could have broken it up with a sledge hammer. Yeah, luckily my thin spot was not on the side of the lift... But goes to show how uneven it was. IIRC all my anchor points were close to 4. I got a killer deal on my 4post second hand anyhow, so it would have been hard to justify a new 2 post. Ferg |
| URY914 |
Sep 29 2009, 12:15 PM
As a general question, are new 2 posts cheaper than a 4 post?
| gandalf_025 |
Sep 29 2009, 12:39 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,523 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
I just checked the open area between the rails on my 4 post lift and it is 39" wide.
I have removed 911 and 914/6 engines and trans with it and the only issue I had was the tip of an Extractor exhaust on a 911 engine stuck out more than that.. If I had removed that muffler first, it would have been no problem. The 2 post lifts seem to have the advantage for working on brakes and suspension, but since I park cars on mine for winter storage, I feel a lot more secure on my floors with the 4 post and it is movable with wheels when you want it out of the way. I had mine installed in the middle bay of my garage, But now, a year later. I realize it would be better in the left side bay.. I already moved power to the new location and next time I take the car down, I'll put the wheels on it and move it over. Easy and simple. Guess it is a personal preference thing. I have never checked the clearances, But is there a chance of hitting the post of a 2 Post lift with the door of a car parked under it. I know that if it was possible, I'd end up doing it somehow.. |
| carr914 |
Sep 29 2009, 06:03 PM
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 132,449 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
The garage floor in my 60 year old house was 14" thick. (IMG:style_emoticons/default/flag.gif) My 4 Post ain't going anywhere. I'll be doing a motor install soon, so I'll let you know how it gos
T.C. |
| JmuRiz |
Sep 30 2009, 09:02 AM
Thanks for the info guys:
Ferg and gandalf_025: Do you guys have the BendPak HD-9 that allows you to expand the ramps from 37" to 44"? I'd love to get a 2-post, it's just that I'll be storing a car ontop of another car most of the year and without a drive-on option for the 2-post lifts I may be SOL...hence the 4-poster with a sliding jack seems like the best choice. I 'should' have 5" of reinforced concert in my garage, if the builder built to spec...but you never know. |
| aircooledtechguy |
Sep 30 2009, 09:39 AM
I'd love to get a 2-post, it's just that I'll be storing a car ontop of another car most of the year and without a drive-on option for the 2-post lifts I may be SOL...hence the 4-poster with a sliding jack seems like the best choice. I have a 2 post Rotary and routinely park one car under another (provided the oil dripper is on the bottom (IMG:style_emoticons/default/shades.gif) ) Even without the 4' extensions you don't have to run the lift all the way up to get a Porsche under another car. . . I wouldn't make that deter you from a 2 post lift. |
| Ferg |
Sep 30 2009, 09:46 AM
Thanks for the info guys: Ferg and gandalf_025: Do you guys have the BendPak HD-9 that allows you to expand the ramps from 37" to 44"? I'd love to get a 2-post, it's just that I'll be storing a car ontop of another car most of the year and without a drive-on option for the 2-post lifts I may be SOL...hence the 4-poster with a sliding jack seems like the best choice. I 'should' have 5" of reinforced concert in my garage, if the builder built to spec...but you never know. Mine is a older bend pak 7500. |
| Jakeodoule |
Sep 30 2009, 10:00 AM
Member ![]() ![]() Group: Members Posts: 353 Joined: 10-October 08 From: Des Moines Iowa Member No.: 9,630 Region Association: Pacific Northwest |
I have a 2 post lift and I agree, If your going to use it for "working on the car" it can't be beat. The thought of putting my car on the lift and then jacking it up... (IMG:style_emoticons/default/confused24.gif) What if you want all four wheels off the car/ramp at the same time?
The only real benift to a 4 poster is the speed it takes to get the car up in the air. You drive on, hit the button. The 2 poster you have to position the car just right and then position all the arms and that takes a little time (like 3 minutes) and invovles bending over at each wheel. I have put marks on the floor for each of my cars and then know exactly where to park each time. I also have parked stuff under my car while its on the lift all the time. I think the 2 poster looks better in the garage as well. Less stuff more car (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 29th April 2026 - 05:16 PM |
