Floor pan rust removal / prevention |
skiking |
Sep 29 2009, 01:12 PM
Newbie Group: Members Posts: 23 Joined: 15-September 09 From: Rapid City Member No.: 10,811 Region Association: None |
1975 914 - one thing leads to another!
While working on brakes, I found rust in the recessed area of the driver's floor pan where the pedal braket is bolted down. Apparently moisture has gathered or sat in this low area of the floor pan. I'm going to use a small metal brush to remove as much rust as possible. I'd appreciate advice on any products I could use to remove the remaining rust, and products I could use to coat the area to prevent further oxidation at this location. Thanks, Robbie |
Lo-Fi Version | Time is now: 19th May 2024 - 02:20 AM |
