would it look gay?, boxster style engine vents |
my15window |
Apr 2 2003, 07:47 PM
Member Group: Members Posts: 61 Joined: 23-March 03 From: fort collins Co. Member No.: 465 |
(IMG:style_emoticons/default/unsure.gif) how come nobody puts side vents in their car?? Is that like putting on a whale tail? (IMG:style_emoticons/default/confused24.gif)
SirAndy |
Apr 3 2003, 08:51 PM
Resident German Group: Admin Posts: 41,641 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
ok, i just went and had a look at the MR2 vents (on a MR2). i doubt they would be very beneficial on a 914. they mount flat, they're NOT scoops unless you would mount them in a angle, like 45+ degrees or so. if you mount them flat, they would not push air into the engine compartment. in fact, the air going by would create a under-pressure and suck air out of the engine-comp! even if you run a closed tube from the vent to the air intake, you'd still have the engine sucking against the under-pressure on the outside. not good. now, if someone had a additional scoop-like cover that would go over the vent on the outside, that would work. and probably look pretty stupid ...
just my 2 cents, Andy |
Lo-Fi Version | Time is now: 17th May 2024 - 09:17 PM |
