Help
Search
Members
Calendar
Full Version:
FS/WTB: 914 Parts
914World.com
The 914 Forums
Classified Forums
FS/WTB: 914 Parts
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
Moved:
FS: 944 Turbo Fuse Box from '86
(-- replies)
WTB: Muffler & Exhaust/Heat Exchangers for 74 2.0
(1 replies)
FS 2005 5 speed subi trans 700$
(5 replies)
FS: Used Front Bumper Plugs, Rear Strut Nut Covers SOLD
(4 replies)
FS: 2 Repro 73-74 Driver Side Warm Air Guide SOLD
(4 replies)
WTB front sway bar
(2 replies)
WTB - Seat Hinge
(1 replies)
WTB: left and right quarter glass post / pillar
(2 replies)
Fs: 911E 6 cylinder motor
(4 replies)
WTB miscellaneous parts
(1 replies)
FS: 2 914-6 Transmission Mounts $210 shipped.
(0 replies)
WTB SIDE trim for Engine Compartment lid
(1 replies)
FS: Complete Weber 44 idf set up SOLD
(4 replies)
WTB or WTT Center Hinged Map Box and or Pad
(1 replies)
FS 914 Flywheel
(2 replies)
F-S : DELLORTO DRLA 40s
(0 replies)
WTB: single tire 225/ 45-15
(1 replies)
Interior items for sale Seats, Back pad, door panels, center console
(2 replies)
DELETE: WTB: Heater Fan Mount Plate & 3 bolts
(1 replies)
FREE - Rear Bumper Pad
(1 replies)
WTB: Sheet metal used, cheap - see pics
(2 replies)
WTB: Inside Door Latch Handles
(1 replies)
WTB - Fuchs 15X8 Complete Set of 4
(9 replies)
F/S vdo speedo drives,cir-clips 901, synchro rings 901 and more
(12 replies)
FS: Original 2-Green Dot Springs
(3 replies)
Updated list with more 914-6 & 914 parts
(3 replies)
WTB Fuel Cap Gasket
(2 replies)
FS New in box two Lobro CV Joints
(8 replies)
FS/ Updated list 914-6 & 914 parts
(8 replies)
FS: Megaphones exhaust
(0 replies)
WTB: 944 Stub axle spacers
(2 replies)
Moved:
Porsche 914 Enthusiast Auction
(-- replies)
WTB Motor Mount for Side shift conversion.
(6 replies)
FS: New Front Brake Rotors 1973-76
(1 replies)
Wtb - muffler bracket - Got one!
(1 replies)
WTB: 901 limited slip differential
(2 replies)
FS: 1972 1.7 L engine parts
(0 replies)
FS: Set of 4 Mahle alloy wheels and tires, SOLD
(8 replies)
Found. Please delete!
(2 replies)
F/S Real 15x8 Fuchs
(2 replies)
FS: New 4 Bolt Rear Rotors Sold
(2 replies)
WTB Blaupunkt parts...
(2 replies)
FS: NOS Front Turn Signal Assembly $185 EACH shipped
(1 replies)
FS: ZF Remaufactured Steering Rack SOLD
(5 replies)
WTB: 911 front end --
(2 replies)
WTB: Upper Rear Trunk Latch
(1 replies)
WTB 73 or later 1.7 TB
(2 replies)
WTB Big fat cylinders
(1 replies)
pre 75 bowlsby wiring harness
(1 replies)
FS: 1972 1.7L engine parts
(0 replies)
FS: Misc parts (many new) All Sold
(13 replies)
FS: Used Alloy Lug Nuts $65 Shipped
(1 replies)
WTB - Door Jam Vent (Passenger Side 1973 2.0)
(1 replies)
WTB: "B" first gear set for 901
(0 replies)
WTB - factory front and rear sway bars
(3 replies)
FS - 3.0 SC engine
(0 replies)
Horn base Plate
(7 replies)
Still need Trigger points
(5 replies)
WTB Drivers front fender and early doors
(0 replies)
Misc NOS Parts Rubber Backed Speed Nuts, SOLD
(5 replies)
FS: Aftermarket Trunk Hinges $25 shipped
(0 replies)
wtb-- dash top
(5 replies)
WTB: 1.7 Muffler Bracket/Exhaust Hanger- FOUND!
(5 replies)
FS: Spring cleaning parts
(6 replies)
WTB - distributor
(6 replies)
FS: 914/6 Throttle Pivot Conversion Kit
(1 replies)
FS: Pickles Parts (Many Unused)
(77 replies)
FS:Weltmeister springs
(4 replies)
custom hood for water cooleed projects
(15 replies)
FS: 2 OEM 914-6 GT flares - SOLD
(3 replies)
WTB - Fuel Pump Mounting Plate from a '75-'76
(5 replies)
WTB - Lower Headlight Area (driverside)
(2 replies)
WTB an OE914 6 bulkhead mount
(4 replies)
FS: SOLD SOLD Transmission Shift Rod $22.50 Shipped
(4 replies)
WTB: Donate or will Buy,, Desperate !
(14 replies)
FS trans, dashes, seat, targa tops and more
(23 replies)
WTB: 2.0 motor Will be using Carbs---FOUND ONE.
(4 replies)
F-S : One OEM "Fog-Light"
(3 replies)
Help me with some parts.
(5 replies)
Free to good home
(1 replies)
(0 replies)
FS/ early license plate lights
(4 replies)
F-S : Pair of Heater Valves / "Flappers"
(1 replies)
WTB/WTT: Early Boge Struts
(3 replies)
FS: Rear Stiffening Kit pieces
(6 replies)
WTB or FREE Seat Belt Logic Relay
(2 replies)
WTB Taco Plate with Sending Unit
(3 replies)
WTB Flaps for return air &rubber sheild for block sensor
(3 replies)
FS Small Collection of Parts
(6 replies)
FS/Trade Metal Leve 20/10/std main bearings
(7 replies)
WTB: Short Rear Valence
(2 replies)
FS: Billet Aluminum Window Regulator Handles
(10 replies)
WTB LE style front spoiler.
(1 replies)
FS: Brown Interior
(35 replies)
WTB-Drain funnel for top of rain drain hose
(2 replies)
FS: Engine parts
(1 replies)
WTB Lightened -4 Flywheel
(0 replies)
FS:Engine/Stand $45 Picked Up
(0 replies)
Delete
(3 replies)
WTB: Brake light switch
(5 replies)
FS: Timing Chain Tensioners. **SOLD**
(2 replies)
FS-Beautiful Tan perlon Footrest from 914-6
(3 replies)
WTB - 12 pin Female connector
(5 replies)
F/S msds high flow cone filter 1.7L
(3 replies)
914-6 Heat Exchangers $600 b/o plus shipping
(1 replies)
FS 914 bumpers b/o plus shipping
(1 replies)
FS: 1.7 FI parts
(1 replies)
FS:Air Cond parts
(3 replies)
WTB - Relay Board Cover for 1973 2.0
(2 replies)
WTB - Turn Signal Bucket
(2 replies)
FS 914-6 Engine Lid $100 b/o plus shipping
(0 replies)
FS 914-6 14x5 1/2 Fuchs $375 b/o plus shipping
(0 replies)
FS Fuel Injection for 2ltr
(8 replies)
WTB: tailshift trans in PNW
(3 replies)
WTB front sway bar setup
(3 replies)
WTB - Long Screw Which Holds Down Relay Board Cover
(3 replies)
FS: SALE PENDING Bursch in great shape $50 + shipping
(3 replies)
WtB a windshield in the So Cal Area
(6 replies)
WTB: WTT: Mirror Parts
(1 replies)
FS Engamn Inner long Kit Un-used $250 shipped
(1 replies)
FS New in box Pagid Orange Brake Pads
(2 replies)
For Sale 1Tail Shift and 1 Side Shift Trans
(2 replies)
FS: Big Brakes for "Early" struts
(5 replies)
WTB: FOG LIGHT TRIM RING / OR ENTIRE FOG LIGHT
(5 replies)
WTB Seat Parts
(5 replies)
WTB: J-Pipe cap
(4 replies)
For Sale – Pair of 914 Seats - $125
(2 replies)
FS - 2.0 Fuchs x 4 = $400
(4 replies)
WTB- 2.0l Heads
(4 replies)
WTB: Thermostat cores. Need not function. Still looking
(13 replies)
WTB set of two 7x16 fuch wheels 23.3 offset
(9 replies)
WTB: Hinged Black Center Pad with storage box
(1 replies)
WTB: Clutch Pedal or Pedal Asy.
(4 replies)
WTB: Nice upper dash pad
(0 replies)
FS:1977 911S engine
(1 replies)
FS: Steering Wheels & Hubs Late 914-4 -Dino & Momo
(2 replies)
FS -gauges, side shifter, shift knob
(3 replies)
Free: Late model big rubber bumpers
(7 replies)
Need Cylinder Heat Temperature
(5 replies)
WTB: 73-74 OEM Gray Loop Carpet Set
(7 replies)
Sold! 10 Piece new Perlon Carpet set
(10 replies)
FS: Restored and new parts list updated
(14 replies)
WTB: Tripod bracket And Shaft (smog)
(1 replies)
WTB: 1 Chrome Trim Corner Piece
(3 replies)
FS: Mahle wheel
(0 replies)
FS: Solex Single Carb Set up SOLD Pending Payment
(0 replies)
FS: NOS Speedometer Angle Drive $80 shipped SOLD
(3 replies)
SOLD SOLDFS: New Manifolds $40 Shipped
(1 replies)
FS: 2.0L SSIs / Chrome Bumper + Top
(2 replies)
WTB: NOS Bosch Fuel Pump for a FI 73 914 2.0
(6 replies)
click here
Invision Power Board © 2001-2024
Invision Power Services, Inc.
