Full Version: FS/WTB: 914 Parts
914World.com > The 914 Forums > Classified Forums > FS/WTB: 914 Parts
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90
  1. Fs: 911E 6 cylinder motor (4 replies)
  2. WTB miscellaneous parts (1 replies)
  3. FS: 2 914-6 Transmission Mounts $210 shipped. (0 replies)
  4. WTB SIDE trim for Engine Compartment lid (1 replies)
  5. FS: Complete Weber 44 idf set up SOLD (4 replies)
  6. WTB or WTT Center Hinged Map Box and or Pad (1 replies)
  7. FS 914 Flywheel (2 replies)
  8. F-S : OEM stock FRONT Porsche 914 SWAY BARS (1 replies)
  9. F-S : DELLORTO DRLA 40s (0 replies)
  10. WTB: single tire 225/ 45-15 (1 replies)
  11. Interior items for sale Seats, Back pad, door panels, center console (2 replies)
  12. (FOUND) WTB Heater Fan Mount Plate & 3 bolts (1 replies)
  13. FREE - Rear Bumper Pad (1 replies)
  14. WTB: Sheet metal used, cheap - see pics (2 replies)
  15. WTB: Inside Door Latch Handles (1 replies)
  16. WTB - Fuchs 15X8 Complete Set of 4 (9 replies)
  17. F/S vdo speedo drives,cir-clips 901, synchro rings 901 and more (12 replies)
  18. FS: Original 2-Green Dot Springs (3 replies)
  19. Updated list with more 914-6 & 914 parts (3 replies)
  20. WTB Fuel Cap Gasket (2 replies)
  21. FS New in box two Lobro CV Joints (8 replies)
  22. FS/ Updated list 914-6 & 914 parts (8 replies)
  23. FS: Megaphones exhaust (0 replies)
  24. WTB: 944 Stub axle spacers (2 replies)
  25. Moved: Porsche 914 Enthusiast Auction (-- replies)
  26. WTB Motor Mount for Side shift conversion. (6 replies)
  27. FS: New Front Brake Rotors 1973-76 (1 replies)
  28. Wtb - muffler bracket - Got one! (1 replies)
  29. WTB: 901 limited slip differential (2 replies)
  30. FS: 1972 1.7 L engine parts (0 replies)
  31. FS: Set of 4 Mahle alloy wheels and tires, SOLD (8 replies)
  32. Found. Please delete! (2 replies)
  33. F/S Real 15x8 Fuchs (2 replies)
  34. FS: New 4 Bolt Rear Rotors Sold (2 replies)
  35. WTB Blaupunkt parts... (2 replies)
  36. FS: NOS Front Turn Signal Assembly $185 EACH shipped (1 replies)
  37. FS: ZF Remaufactured Steering Rack SOLD (5 replies)
  38. WTB: 911 front end -- (2 replies)
  39. WTB: Upper Rear Trunk Latch (1 replies)
  40. WTB 73 or later 1.7 TB (2 replies)
  41. WTB Big fat cylinders (1 replies)
  42. pre 75 bowlsby wiring harness (1 replies)
  43. FS: 1972 1.7L engine parts (0 replies)
  44. FS: Misc parts (many new) All Sold (13 replies)
  45. FS: Used Alloy Lug Nuts $65 Shipped (1 replies)
  46. WTB - Door Jam Vent (Passenger Side 1973 2.0) (1 replies)
  47. WTB: "B" first gear set for 901 (0 replies)
  48. WTB - factory front and rear sway bars (3 replies)
  49. FS - 3.0 SC engine (0 replies)
  50. Horn base Plate (7 replies)
  51. Still need Trigger points (5 replies)
  52. WTB Drivers front fender and early doors (0 replies)
  53. Misc NOS Parts Rubber Backed Speed Nuts, SOLD (5 replies)
  54. FS: Aftermarket Trunk Hinges $25 shipped (0 replies)
  55. wtb-- dash top (5 replies)
  56. WTB: 1.7 Muffler Bracket/Exhaust Hanger- FOUND! (5 replies)
  57. FS: Spring cleaning parts (6 replies)
  58. WTB - distributor (6 replies)
  59. FS: 914/6 Throttle Pivot Conversion Kit (1 replies)
  60. FS: Pickles Parts (Many Unused) (77 replies)
  61. FS:Weltmeister springs (4 replies)
  62. custom hood for water cooleed projects (15 replies)
  63. FS: 2 OEM 914-6 GT flares - SOLD (3 replies)
  64. WTB - Fuel Pump Mounting Plate from a '75-'76 (5 replies)
  65. WTB - Lower Headlight Area (driverside) (2 replies)
  66. WTB an OE914 6 bulkhead mount (4 replies)
  67. FS: SOLD SOLD Transmission Shift Rod $22.50 Shipped (4 replies)
  68. WTB: Donate or will Buy,, Desperate ! (14 replies)
  69. FS trans, dashes, seat, targa tops and more (23 replies)
  70. WTB: 2.0 motor Will be using Carbs---FOUND ONE. (4 replies)
  71. F-S : One OEM "Fog-Light" (3 replies)
  72. Help me with some parts. (5 replies)
  73. Free to good home (1 replies)
  74. FS: 1972 1.7L engine parts (0 replies)
  75. FS/ early license plate lights (4 replies)
  76. F-S : Pair of Heater Valves / "Flappers" (1 replies)
  77. WTB/WTT: Early Boge Struts (3 replies)
  78. FS: Rear Stiffening Kit pieces (6 replies)
  79. WTB or FREE Seat Belt Logic Relay (2 replies)
  80. WTB Taco Plate with Sending Unit (3 replies)
  81. WTB Flaps for return air &rubber sheild for block sensor (3 replies)
  82. FS Small Collection of Parts (6 replies)
  83. FS/Trade Metal Leve 20/10/std main bearings (7 replies)
  84. WTB: Short Rear Valence (2 replies)
  85. FS: Billet Aluminum Window Regulator Handles (10 replies)
  86. WTB LE style front spoiler. (1 replies)
  87. FS: Brown Interior (35 replies)
  88. WTB-Drain funnel for top of rain drain hose (2 replies)
  89. FS: Engine parts (1 replies)
  90. WTB Lightened -4 Flywheel (0 replies)
  91. FS:Engine/Stand $45 Picked Up (0 replies)
  92. Delete (3 replies)
  93. WTB: Brake light switch (5 replies)
  94. FS: Timing Chain Tensioners. **SOLD** (2 replies)
  95. FS-Beautiful Tan perlon Footrest from 914-6 (3 replies)
  96. WTB - 12 pin Female connector (5 replies)
  97. F/S msds high flow cone filter 1.7L (3 replies)
  98. 914-6 Heat Exchangers $600 b/o plus shipping (1 replies)
  99. FS 914 bumpers b/o plus shipping (1 replies)
  100. FS: 1.7 FI parts (1 replies)
  101. FS:Air Cond parts (3 replies)
  102. WTB - Relay Board Cover for 1973 2.0 (2 replies)
  103. WTB - Turn Signal Bucket (2 replies)
  104. FS 914-6 Engine Lid $100 b/o plus shipping (0 replies)
  105. FS 914-6 14x5 1/2 Fuchs $375 b/o plus shipping (0 replies)
  106. FS Fuel Injection for 2ltr (8 replies)
  107. WTB: tailshift trans in PNW (3 replies)
  108. WTB front sway bar setup (3 replies)
  109. WTB - Long Screw Which Holds Down Relay Board Cover (3 replies)
  110. FS: SALE PENDING Bursch in great shape $50 + shipping (3 replies)
  111. WtB a windshield in the So Cal Area (6 replies)
  112. WTB: WTT: Mirror Parts (1 replies)
  113. FS Engamn Inner long Kit Un-used $250 shipped (1 replies)
  114. FS New in box Pagid Orange Brake Pads (2 replies)
  115. For Sale 1Tail Shift and 1 Side Shift Trans (2 replies)
  116. FS: Big Brakes for "Early" struts (5 replies)
  117. WTB: FOG LIGHT TRIM RING / OR ENTIRE FOG LIGHT (5 replies)
  118. WTB Seat Parts (5 replies)
  119. WTB: J-Pipe cap (4 replies)
  120. For Sale – Pair of 914 Seats - $125 (2 replies)
  121. FS - 2.0 Fuchs x 4 = $400 (4 replies)
  122. WTB- 2.0l Heads (4 replies)
  123. WTB: Thermostat cores. Need not function. Still looking (13 replies)
  124. WTB set of two 7x16 fuch wheels 23.3 offset (9 replies)
  125. WTB: Hinged Black Center Pad with storage box (1 replies)
  126. WTB: Clutch Pedal or Pedal Asy. (4 replies)
  127. WTB: Nice upper dash pad (0 replies)
  128. FS:1977 911S engine (1 replies)
  129. FS: Steering Wheels & Hubs Late 914-4 -Dino & Momo (2 replies)
  130. FS -gauges, side shifter, shift knob (3 replies)
  131. Free: Late model big rubber bumpers (7 replies)
  132. Need Cylinder Heat Temperature (5 replies)
  133. WTB: 73-74 OEM Gray Loop Carpet Set (7 replies)
  134. Sold! 10 Piece new Perlon Carpet set (10 replies)
  135. FS: Restored and new parts list updated (14 replies)
  136. WTB: Tripod bracket And Shaft (smog) (1 replies)
  137. WTB: 1 Chrome Trim Corner Piece (3 replies)
  138. FS: Mahle wheel (0 replies)
  139. FS: Solex Single Carb Set up SOLD Pending Payment (0 replies)
  140. FS: NOS Speedometer Angle Drive $80 shipped SOLD (3 replies)
  141. SOLD SOLDFS: New Manifolds $40 Shipped (1 replies)
  142. FS: 2.0L SSIs / Chrome Bumper + Top (2 replies)
  143. WTB: NOS Bosch Fuel Pump for a FI 73 914 2.0 (6 replies)
  144. FS: Restored Gas Cap VW logo $25 shipped SOLD (2 replies)
  145. FS: Engine Valve Cover Bails (2 replies)
  146. WTB - Correct hose clamps for drain funnels/tubes in engine bay (3 replies)
  147. WTB (1 replies)
  148. WTB: Sheetmetal in the Houston, TX area (4 replies)
  149. WTT/FS - 914-6 factory oil filler tube with cap (2 replies)
  150. FS- 914 Rear V-Calipers with spacers (13 replies)
Invision Power Board © 2001-2013 Invision Power Services, Inc.
