To tighten the pinion shaft nut..the one under the speedo drive.
I either did not tighten it or it came loose.
Apon removing the gearbox I could not turn the output shafts by hand. They were that tight.
Here is the bad:
most of gear stack ok, maybe 1 gear got beat up
R@P trashed.
Here is the good:
I found out how cool and willing to help people are on this forum.
Call webster I created some new cuss words.
I Found out RedLine gear oil is not the right oil for our gearboxes. Lucky for me I found out before it trashed my gearbox
I am reminded again how lucky I am to have a lift.
Nobody else who have read this post, is going to leave this nut loose.
I'm very lucky I only went about 3 miles and was going slowly to check things out.
ring damage
pinion? Damage
Gear stack damage
