am I happy with it? happy doesn't cover it
the kit is mostly pre-cut, I just had to notch where screw holes are and trim behind the gauges... it's 2 pieces, a high quality foam, very nice feel and the vinyl is as supple as real leather, nicer than stock, imo. the dash vents are pre-cut so the install was pretty easy.
I used a small putty knife that is bent, used that to get it up under the seal smoothand just worked it to where it wraps behind the dash. then lifted it up a little bit at a time and sprayed 3m 80 spray adhesive, then smoothed it out from the windshield back...
btw, if you think these look good, wait til you see the door panels
all courtesy of morph at 914ap.com his work is STELLAR!
