QUOTE(ILM914 @ Oct 6 2009, 04:17 PM)
Hello: Any help is appreciated I'm still looking for the following parts:
Battery Tray and support
Bent fuel injector lines Rubber (4)
Stud for Thermostat Bracket ( into case)
Rear Shifter boot (where rod goes into plastic housing)
E-Brake retaining clip/s (2)
E-brake cable rubber boots/seals
Thank you, Joe
in the order you listed you can get them at
pelican parts
auto atlanta
you local hardware store (even of same hardness 4.8 i think but maybe 8.8)
pelican parts (check under 911,912 etc..)
pelican parts
the boots i have never seen except with cable purchases they are already on the cables but you can try auto atlanta..
