QUOTE(flipb @ Oct 9 2009, 09:09 AM)
I'd love to get confirmation of the expected behavior.
I get the green light in the speedo any time any of my lights are on - parking or headlights, regardless of fog lights.
My High Beam indicator (in the Tach) doesn't work.
But I think my IP wiring is a little screwy - for instance, using either turn signal causes both arrows to flash, although the turn signals themselves actually work properly.
If anyone can confirm expected behavior, I'd be much obliged.
One question - do cars without fog lights have the green light in the Speedo? What activates it if there are no fog lights?
I believe there is only one bulb inside the turnsignal indicator, which would flash both indicators when either side is activated. Mine did the same thing until about two months ago. Now, the left signal makes the indicator work but my right signal does not (both signals work on the outside front and rear)?
My green indicator light turns off when my headlights go on!
EDIT: I'm going to try and scan in the whole owners manual because I haven't seen anything like that on this site. I'll probably post it in my blog unless one of the admins would like it for the info area.
