1973 Porsche 914 2.4L
This is a very unique car. My wife and I have spent the last 11months completely restoring this car. At the finish point we have an opportunity to purchase a house.
-New engine 2336cc 9:1 compression 86Web Cam 48Webbers ext…
-New Transition
-New interior, too much to list (see picture)
-New paint
-New tires
-911 sc front end, with New calipers all around
-5 lug conversion on rear drilled rotors and hubs
-New bushings/turbo tie rods/throttle cable/Speedo cable
-New all rubber/seals/carpet
-New European header system with custom stainless steel exhaust
-HID headlights/ all other are LED lights
-Reupholstered center council
-This car has never been in an accident
-Flared not with fiberglass
-Car has 145 miles on it, since we finished
There is much more, I have receipts of all I spent and bought.
If you are interested (Meaning: you have the actual money) give me a call 510 566 6740
7am-9pm
There will be no test-driving unless you can show me the money.
Please don’t waste my time if you have no interest in buying.
-Roman
I knew I forgot something,
-the engine is a 4cly big bore from a 2.0L original the car was a 914-4,
-engine was done by Gervais Engine & Machining. I have phone number if you are interested in speaking with the guy.
-Engine is still under warranty.
-Transition is a 1973 so a side shift. Done by: Porsche Restoration Crockett, CA
-Porsche Restoration Crockett, CA did most of the work on the car: breaks/suspension /engine installation ext.
-suspension in rear is 120lb coil-over, front is from a 1979 911 sc
-all bushings/ball joints have been replaced
-also Dino mated the entire car. For sound protection
-breaks in front are the 911 sc calipers with slotted rotors
rear are 914-6 set up
-the car is in the best shape you are free to see for yourself
-no rust!
-No a/c
-I have a defrost fan installed (since I don’t have a heater)
-also has heated seats
