Black&White
Oct 9 2009, 04:35 AM
Hello every one I just got a 1974 914 I am starting to get it to be my DD but i have two problems that i have to fix.
1) The turn signals turn on but dont flash and no indication in the inside. could it be just the relay?
2)The e brake dont work how hard is it to install a new one or can it be a simple fix
I am sure I have more question and i will post pics very shortly
Brad
blitZ
Oct 9 2009, 06:31 AM
Check your grounds when you have something electrical not working. If the grounds are fine, then it's probably the relay.
The e-brake just may need adjusting. Jake the car up and see if the brakes are rear bakes are working at all. In my case, I needed rebuilt calipers to get my e-brake back as my rear brakes were not working at all.
