QUOTE(Dr Evil @ Oct 9 2009, 08:33 PM)
A sheared roll pin can cause this. Is the transmission stuck in a gear, or not able to be put in any gear (stuck in neutral)? This is not likely a bushing as a bushing typically only messes up the left-right selection, but you still have fore and aft.
When you say rebuilt and you have receipts, who did the work and what do you have receipts for??? Just because it was "rebuilt" does not mean it was done correctly (shift fork maladjustment can cause what you are experiencing), and receipts only mean that parts were bought. If the rebuild was not done right you would get what you have. If it is an alignment issue, you will be able to tell by removing the selector console. Check to see if the selector rod is moving first and then remove the console and check it. If you cant put the selector in neutral for the removal you will need to drive the roll pin out of the end and remove the boll end first.
But, one step at a time.
Thanks everyone i figured it out it was the linkage from the firewall to the shift rod bar came loose the bolt that hold them together came out it was a pain to get to with no jack but it fixed and drive great again. thanks for everyone help again I am sure i have more Questions as i come to learn these cars I was a 4x4 guy but wanted to do something new.
