QUOTE(oldschool @ Oct 9 2009, 11:02 PM)
what is a good sign to look for, or sound,to indicate I need a valve adjustment ?
Usually if the valves are tight you will have LESS valve train noise while idling and if they are really tight (as in no clearance left), it becomes difficult to re-start the engine especially when it warms up. This is due to the valves *just* hanging open causing a loss of compression at slow engine speeds. At this point, you will also notice a rough idle.
The valve clearance should be .006" and checked every 3K miles.
