Big Metal for Local Pickup DFW TX Pictures on request #
Most shipped USPO flat rate $9.85 medium size box PM or Email with zip code for shipping $. Paypal great. Checks ok. Will ship when cleared.
bandjoey@sbcglobal.net pictures on request
# Rear Trunk Lid w/rust on the center back edge at the latch hole. Metal work required. 10.00
# Front Trunk Lid with almost no rust but stress bends on the hinge area where it looks like someone closed the lid with the gas cap sitting on the firewall. Metal work needed 10.00
# Left Door Gutted and sprayed with epoxy undercoat. Bottom edge has bad metal from water pooling inside the door and rust holes poking through. Rest of the door is in good shape. 29.14
# Right Door Gutted and sprayed with epoxy undercoat. Bottom edge has bad metal from water pooling inside the door and rust holes poking through. Rest of the door is in good shape. 29.14
# Engine Lid sprayed with epoxy undercoat – no grill work 19.14
Drivers Door Glass 19.14
Drivers Door Triangle Glass 9.14
# Rear Window Glass 39.14
Left Door Vertical Window Tracks 9.14
Left Door Window Regulator 9.14
Left Door Inside Handle Locking Rod (to door lock) 1.14
2 Black Inside Door Handle Buckets 9.14
Right Door Window Regulator 9.14
2 Window Crank Handles 1 new style 1 old style 9.14 both
Early Style Steel spare tire Wheel 15.00
Late Style Steel spare tire Wheel 15.00
Set of Front Trunk Hinges 9.14 pair
Set of Rear Trunk Hinges 9.14 pair
2 Black Plastic Door Threshold Strips 9.14 pair
2 Black Plastic Carpet Hold downs on Threshold 9.14 pair
Rear Taillight Bucket Fair Chrome 9.14
Rear Taillight Bucket Fair Chrome Rusted Bulb Sockets 5.14
2 Horns. 1 works great. 1 no workie. 9.14 both
Set of Visor Metal Frames w. Covers – Inside Foam gutted out 8.00
Complete Glove Box, Door, Lock & Support 59.14
Targa Locking Latch Right Rear 9.14 Sale Pending
Targa Locking Latch Left Rear 9.14 Sale Pending
# Back Pad Rubber Insulator Pad 9.14
# Engine Firewall Insulator Pad 9.14
Contact Switch for Door Light w/gasket 4.00
Wiper Crank Mechanism with Motor 37.00
Set of Side Marker Lens Good Shape 25.00
Set of Turn Signal Lens w/Gaskets 18.00 Sale Pending
Left Turn Signal Bucket 20.00
Right Turn Signal Bucket 20.00
Set of Headlight Surround Covers 9.14 each or 15.00 pair
3 – Instrument Panel Gas / Handbrake Light Guage 18.00 each
Rear Valance with ½ Hole trimming Over the Tail Pipe Painted 35.00
4 Engine Lid Locks 12.00 each
B Pillar Trim Drivers – average 8.00
B Pillar Trim Both Sides Good 12.00 each
Roll Bar Pad – Good pad with usual cracks and one end buggered up 8.00
Pair of A Pillar Inside Upholstery Trim 20.00
Center Seat Tray – Plastic, not with Padded Top 8.00
Engine Lid Drain Funnel – no tube 6.50
Shift Lever and Base Unit –No Knob 27.00
Front Hood Latch & Lock Both Pieces 22.00
Rear Trunk Lid Push Button – No Key – w/Rubber Gasket 25.00 SALE PENDING
Rear Trunk Lid Latch Receiver (on body) 8.00SALE PENDING
Rear Trunk Lid Lock Mechanism 24.00 SALE PENDING
Pair Dog Bones Bumper 10.00
Window Post End Caps 22.00 each
Headlight Assembly Pivot Bracket 5.00
Dash Metal Instrument Panel for Tach/Speedo/GasGuage 15.00
Fuse Block 8.00
