Full Version: intermittent injector
elsargento
Running Gumout injector cleaner thru the system. Thinking about sending all 4 to witchhunter if cleaner doesn't work. Is it just that the solenoids stick then clear then stick? When clear runs like a top.
If I send them to witchhunter do I need to buy new seals or do they come back with them included? welder.gif
type47
By "seals" do you mean the mounting rubber injector seals to the intake manifolds? If so, then I doubt they come from the injector rebuilding company.
underthetire
Believe it or not, Autozone has the O-ring type seals, upper and lowers. Comes in a generic kit for about 8 bucks. Seems most injectors use one of two styles.
2-OH!
Witchhunter is a good deal...Does not come back with seals...Yes, new seals...
2-OH!
