QUOTE(Brad Roberts @ May 6 2004, 09:52 PM)
I'm betting the pilot is toast and it is allowing the input shaft to move around (a lot)
Attached is a photo of the pilot bearing.
Say what?
You don't see a picture?
That's because there was
no pilot bearing!
I dropped the tranny and pulled the fly wheel.
There was nothing in the center.
The PO had balanced and lightened the fly wheel.
I can't remember ever doing anything to it since I bought the car.
Is it really possible that I have been driving it for 7 years with no pilot bearing?
The hole for the bearing is very rough with lots of sharp edges inside.
The shaft only has a few light scuffs that will buff out easily.
I also found that the material sandwiched in the pressure plate is breaking apart.
I am feeling very lucky and very stupid.
Easy fix.
Get new fly wheel and have it machined to match.
Install pilot bearing.
Get new 6 spring early 911 pressure plate.
Drive it 'till I break something else.
