QUOTE(Cire @ Oct 17 2009, 03:47 AM)
I am looking for a new rear brake rotor.
1973
2.0
Drivers side
I can buy a set just in case if its cheaper.
If you are in Vegas or PHX or inbetween, I will be driving through today. = )
Thanks
520-248-2482
Your title say caliper and the text says rotor. New rotor are only about $60 each. It is best to replace them in pairs. I should have a decent one that can be turned. I also have a bunch or rear calipers if that is what you need. Shipping would be $10 for a caliper and $14 for a rotor. I want $40 for a single rear caliper. I would recommend rebuilding it. It may be usable as is but brakes are kind of important.
Rotors only have about 1mm wear limit so used ones are not worth much in my opinion if you have to spend $15 to get them turned.
Bruce
