QUOTE(svsv @ Oct 17 2009, 09:14 PM)
2nd & 4th have dissapeared. I just replaced the ball cup in the rear. They weren't there after that. Now I can hold it were they should be and feel the syncros grab and pull it in then it is in gear; but a normal shift not there at all. The shifter is pretty sloppy. Where have they gone?
New and improved with PUNCTUATION!
We want to help, but we need to be able to read what you are asking us about without our eyes crossing too.
As to your problem, you likely need to replace more then just the ball cup in the rear. If it was gone, and if your shifter is still sloppy, you need to go ahead and replace *ALL* the bushings and 2 cone screws in the shift linkage. Then you will need to readjust your shifter.
Once that is gone, the slop will be removed and you will find 2nd and 4th again.
My guess is that its also hard to find reverse, as it is also on the 2/4 plane.
Zach
