QUOTE(stephenaki @ Oct 19 2009, 07:53 AM)
OK, silly question...maybe...can you get to the thermostat and flap assemblies WITHOUT dropping the motor and pulling the impeller housing? I want to make sure that this is not the oil leak problem as well but would rather not have to drop the motor again.
Yes and no. You don't have to fully drop the motor. You do have to pull the cooling fan. But you have to think about how you are going to do it. You have to remove the cooling fan and dog house, which requires at least a partial drop. I did it over the summer on my car, so I know it can be done.
First - remove all the tin screws you can get to with the engine in place that attach the side tin to the front tin and the dog house. This task is easier when the car is on the ground. Some screws are under the car, so you will have to wait to get to them.
Put the car as high up as you can get the rear to go. Put a good floor jack under the motor. Remove the front tin at this point. Unbolt the engine bar from the car but not the trans mounts, and slowly lower the engine until you can get to the cooling fan. Pull it. There are now 4 bolts holding on the doghouse, remove them and pull it.
replace your cooling flaps, replace the dog house (have fun with this one!
) and put all the other stuff you pulled back on the car. Once the engine is secured back in the car, it will be easy to install the bellows. One of the bolts is a through bolt, so if the car is full of oil you will want to be quick about it. Fish the control wire up through the hole in the tin, lower the car and attach everything up top.
Zach
