I have never done this procedure (Setting the Dwell) and the more I read on it the more confused I become. Isn't setting the gap the same as setting dwell?
Thanks...
Gint
Oct 19 2009, 05:08 PM
Yes it's the same. One is just expressed as a degree of arc instead a distance between the contacts. Dwell angle is the more precise form of measurement for point gap.
Edit: D'oh! I thought dwell was the open angle not closed. Worng again...
Dwell angle is a measure of the duration of time that the primary circuit of the ignition system is closed to energize the primary windings of the coil. It expressed (and measured) in degrees of rotation of the distributor rotor, hence the use of the term "angle".
r_towle
Oct 19 2009, 05:09 PM
The gap is the space between the contact points in the distributor. The base line gap is set at 016. This is set with a feeler gauge and a screw driver.
The Dwell is the measurement (electronically measured) with a dwell meter. It measures how long the contact points dwell in the closed position...thus the dwell.
To increase the dwell, you set the points to a smaller gap...increase dwell, use a bigger gap. There are differences in distributors, in shaft wear, in points sizes etc etc. The ONLY setting that matters is the dwell setting on your car, with your distributor, using your Bosch points.
I could take your points, put them in my car and the dwell would be the same, yet my gap measurement may be different.
All you care about is the Dwell measurement...that is the key number and at the end the baseline gap you have is not relevant...its all about the dwell.
Rich
tabs914
Oct 19 2009, 05:24 PM
Ok...great! I think i get it now. Thanks.
SLITS
Oct 19 2009, 05:32 PM
Ah man, they didn't throw in coil saturation time to futher confuse the issue.
r_towle
Oct 19 2009, 05:34 PM
QUOTE(SLITS @ Oct 19 2009, 07:32 PM)
I figured from you it would be more like...
The gap is how wide you need to spread your cheeks to squeeze it out. The Dwell is how long it takes in the bathroom.
Rich
SLITS
Oct 19 2009, 06:55 PM
Thanks Rich ..... you're on target!
balljoint
Oct 19 2009, 07:40 PM
