QUOTE(SLITS @ Oct 20 2009, 04:23 PM)
The air bleed(s) will be in the highest portion of the piping.
With boiler off........You should have something that looks like a hose spicket on the copper line(s) at boiler returns (two spickets if two zone etc...) Above the spicket you should have a valve or a fitting with a screw in the middle. You have to lift up the water feed lever where the system feed is...(street water)it will put more water in system...close the valve above the hose spicket (or the screw flap valve) and open the hose spicket and let the water run into a bucket. do this to all zones...You should hear water filling the boiler as you bleed system. close the fresh water lever. bleed system down below 12psi..(look at gauge). The auto fill regulator will bring it back to 12 psi..Normal operating when cold. Remember..were not talking about the hose spicket at the bottom of boiler. With boiler on, you should not hear water running in the baseboard. I hope this helps....
