number6
Oct 21 2009, 04:08 PM
I've tried to price fairly - please let me know if I'm off on something.
I'll cross items off this master list as they sell.
Clearing out storage -
EVERYTHING MUST GO!
NO REASONABLE OFFER REFUSED Thanks all.
Extending oil return tubes for 6cyl motors, set of 6, NEW - $80Valve cover gaskets for 6cyl, NEW - $15914-6/911 fan shroud (should fit 2.0-3.0L motors - please double-check) - $45Windshield mouldings, all 3 pieces - $55
Aftermarket windshield rubber moulding (replaces aluminum trim) - $40Rear trunk seal, NEW, aftermarket from CAMP914 - $20
Rear trunk seal, used, aftermarket from CAMP914 - $13
Front trunk seal - $40
Dash face recovering material, 3 available, NEW - $15 each
Hella custom wiring harness for auxiliary lighting, NEW - $25Solid transmission mounts (set), NEW - $40
Bronze pedal bushing set, NEW - $10Assorted shift bushings (all 10 pieces, NEW, except 1 was installed and then removed) - $35Hard start relay kit, NEW - $15150mph speedometer, odometer shows 60792 - $65
150mph speedometer, odometer shows 09668 - $65Tachometer - $65
Combo gauge - $65
Center console temp gauge - $30
Instrument panels, metal, painted but scuffed from storage - $10 each
Rubber gauge rings (2 big center rings, 4 smaller side ones) - $4 each
Targa top front stow clip, NEW - $5Targa top front stow clip, used - $3Taillight housings, left and right - $40Euro taillight lens, driver side, REPAIRABLE - $30
Center caps, ring style (the black ones have been powdercoated - 1 needs to be readhered to backing) - $5 eachVisor clips, needs cleaning! - $15
Dash vents, set of 2 - $15
A-pillar trim pieces - $15
Aluminum door sill & threshold trim - $40 for set
Leather shift knob - $10Shift boot - $5OEM shift knob with crush sleeve - $20Window crank - $7Speaker grilles, with speakers - $40 for setH4 100/90W bulbs, NEW - $15
H4 100/80W bulb, Hella, used, looks to still be good - FREE
Bumper dog bones, 7 available - $4 each
Ignition assembly, aftermarket tumbler & 2 keys, from '75 car (should work with '76 - please double-check!) - $40
Wiper arms set, 3 nuts - $30
'75 1.8 air mass sensor - $25'75 1.8 computer - $25Front steel valance - $30Rear spoiler - $20
number6
Oct 21 2009, 04:13 PM
*SOLD* Extending oil return tubes for 6cyl motors, set of 6, NEW - $80
number6
Oct 21 2009, 04:15 PM
*SOLD* Valve cover gaskets for 6cyl, NEW - $15
number6
Oct 21 2009, 04:17 PM
*SOLD* 914-6/911 fan shroud (should fit 2.0-3.0L motors - please double-check) - $45
number6
Oct 21 2009, 04:21 PM
number6
Oct 21 2009, 04:22 PM
*SOLD* Aftermarket windshield rubber moulding (replaces aluminum trim), used but in great condition - $40
number6
Oct 21 2009, 04:28 PM
Rear trunk seal, NEW, aftermarket from CAMP914, 10ft length - $20
Rear trunk seal, used, aftermarket from CAMP914, 10ft length, great shape except for small blemishes shown - $13
number6
Oct 21 2009, 04:31 PM
Front trunk seal, good shape but needs to be cleaned - $40
number6
Oct 21 2009, 04:34 PM
number6
Oct 21 2009, 04:36 PM
*SOLD* Hella custom wiring harness for auxiliary lighting, NEW - $25
number6
Oct 21 2009, 04:38 PM
Gigamight
Oct 21 2009, 04:43 PM
Can I see a pic of the leather shift knob?
Gigamight
Oct 21 2009, 04:46 PM
And what kind of spoiler is it that you have?
number6
Oct 21 2009, 04:47 PM
*SOLD* Bronze pedal bushing set, NEW - $10
*SOLD* Assorted shift bushings (all 10 pieces, NEW, except 1 was installed and then removed) - $35
number6
Oct 21 2009, 04:49 PM
*SOLD* Hard start relay kit, NEW - $15
Gigamight
Oct 21 2009, 04:50 PM
Oh, sorry, you're still going, I'll wait
number6
Oct 21 2009, 04:55 PM
*SOLD* 150mph speedometer, odometer shows 09668 - $65
Tachometer - $65
Combo gauge - $65
number6
Oct 21 2009, 04:56 PM
QUOTE(Gigamight @ Oct 21 2009, 03:50 PM)
Thanks! I'm about half way through
number6
Oct 21 2009, 04:59 PM
number6
Oct 21 2009, 05:03 PM
*SOLD* Targa top front stow clip, NEW - $5
*SOLD* Targa top front stow clip, used - $3
number6
Oct 21 2009, 05:06 PM
*SOLD* Taillight housings, left and right (one is really dusty) - $40
cracked/broken, but all pieces fit back perfectly;
looks perfect when mounted
number6
Oct 21 2009, 05:09 PM
*SOLD (all 6)* Center caps, ring style, for Fuchs & Cookie Cutters (the black ones have been powdercoated - 1 needs to be re-adhered to backing) - $5 each
detoxcowboy
Oct 21 2009, 05:15 PM
dibs on tail light housings, pending pictures.. NUMBER6 can I get close ups of the edges all around the tail light housings? mine have always been chipped up but I do not want to replace same for same, I would rather buy nos but cannot find them .. joe
pics either here or to detoxcowboy@gmail.com Gracias Numero Sies!
number6
Visor clips, need cleaning! - $15
number6
Oct 21 2009, 05:24 PM
*SOLD* Leather shift knob - $10
*SOLD* Shift boot - $5
*SOLD* OEM shift knob with crush sleeve - $20
*SOLD* Window crank - $7
*SOLD* Speaker grilles, with speakers - $40 for set
a couple broken/missing pieces
number6
Oct 21 2009, 05:25 PM
the included speakers are:
koozy
Oct 21 2009, 05:26 PM
I'll take the center caps
number6
Oct 21 2009, 05:27 PM
number6
Oct 21 2009, 05:29 PM
number6
Oct 21 2009, 05:30 PM
number6
Oct 21 2009, 05:35 PM
*SOLD* Front steel valance - $30
number6
Oct 21 2009, 05:37 PM
*SOLD* Rear spoiler - $20
type47
Oct 21 2009, 05:38 PM
I'd like the yellow engine shroud and the targa top holders. PM sent.
number6
Oct 21 2009, 05:42 PM
And finally...
*SOLD* '75 1.8 air mass sensor - $25
flap is slightly warped, worked fine on my old car,
but let's just say for parts/as core
*SOLD* '75 1.8 computer - $25
i was told this was tested/working
but i never tried it
Gigamight
Oct 21 2009, 05:43 PM
Pm sent on the leather shift knob, I'll take it
number6
Oct 21 2009, 05:45 PM
Thanks, everyone, for your patience!
The pup needs a walk now, but I will get back to all inquiries as soon as I'm back in front of the 'puter.
Gigamight
Oct 21 2009, 05:49 PM
Can you get me dimensions of the spoiler? I need to know the footprint and distance between feet. The PO put a spoiler on the car and it's hideous. I would rather put a simple spoiler like than on than repaint the trunk lid.
carr914
Oct 21 2009, 06:13 PM
Hi Duc
, If number6 is selling parts, you can bet they are Top-Notch - he doesn't buy Junk.
T.C.
bcheney
Oct 21 2009, 06:16 PM
I missed out....would have loved that leather shift knob and those center caps!! You always have the nice stuff Duc!!
steveherman
Oct 21 2009, 06:52 PM
i will take the spoiler.
shipped 34741
craig downs
Oct 21 2009, 07:47 PM
I'll take the steel front valance
number6
Oct 21 2009, 07:57 PM
QUOTE(Gigamight @ Oct 21 2009, 04:49 PM)
The spoiler is stored quite a drive from me, so it may be a couple days before I can get you the measurements. I'll do my best to expedite!
number6
Oct 21 2009, 08:38 PM
QUOTE(carr914 @ Oct 21 2009, 05:13 PM)
Hi Duc
T.C.
T.C., you're making me blush!
This batch is obviously not anywhere near primo like the last. I can't say "top-notch," but everything is as pictured/described. These are just all the extras that have collected over the years, from me going through so many 914s. But look who I'm talking to - you probably have a similar stash x20!
-duc
number6
Oct 21 2009, 08:45 PM
QUOTE(bcheney @ Oct 21 2009, 05:16 PM)
Have you checked with Craig over at CAMP914? I'm pretty sure he has both these items. If I pull the leather shift knob off my 912, I'll let you know. Thanks!
-duc
number6
Oct 21 2009, 08:48 PM
QUOTE(steveherman @ Oct 21 2009, 05:52 PM)
shipped 34741
Hi Steve. Gigamight contacted me first about the spoiler. If it doesn't work out for him (he's waiting on measurements), the spoiler is yours. I'll let you know. Thanks!
-duc
jschaible
Oct 21 2009, 09:12 PM
QUOTE(number6 @ Oct 21 2009, 06:38 PM)
Will the Weltmeister soild transmission mounts fit a sidebox trans coupled to a 1.8L? How are they different than the other trans mounts out there?
Gigamight
Oct 21 2009, 09:20 PM
Thanks Duc, your shift knob will be in my hand the first time my car goes into first gear........ again.
number6
Oct 21 2009, 09:34 PM
QUOTE(Gigamight @ Oct 21 2009, 08:20 PM)
That's a big honor - I better shine the knob up before shipping!
number6
Oct 21 2009, 09:44 PM
QUOTE(jschaible @ Oct 21 2009, 08:12 PM)
There are several trans mounts that I'm aware of, including the stock ones, 911 sport ones, these Weltmeister solid mounts, and Wevo semi-solid mounts. There are probably others that I don't know about.
The solid mounts, I suppose, in theory, would give the most positive shift rod alignment, so the most precise shifting. I can't say, because I've only used the Wevo SS and never looked back. Solid mounts should give you improved shifting over stock, but you will get more vibration. Since I'm no expert on these matters, I would suggest you search this site for lengthier discussions, by more knowledgeable people.
These mounts fit all 914s, so they will work for your application.
-duc
xsurfer
Oct 22 2009, 09:46 AM
QUOTE(number6 @ Oct 21 2009, 03:13 PM)
Which brand of return tubes are those?
What would shipping be to 91011?
Very interested!
