QUOTE(Leo Imperial @ Oct 26 2009, 06:47 PM)
Guessing you edited your response.
So once again. Anyone have a stock rear bar drop link available or know where I can source one?
Yes I did edit my response asking if you needed front or rear after seeing it in the title. Duh.
They are NLA. I put a WTB ad here and did not find one. I do have BMW drop links that can be converted to 914 drop links if you have access to machine shop services. The BMW links are a solid one piece forged aluminum part with a molded in rubber bushings. The bushing must be cut out and the ID bushed down to 30MM. The thickness must machined down to 13mm. 914 bushings will then fit into the drop links.
I have a few pairs of them if you are interested in making a pair. They are slightly shorter than the 914 drop links. We make a couple of pairs and tried them out on an autocross car with positive results.
Can post some pictures or give more details if you are interested.
Bruce
