Geezer914
Oct 26 2009, 10:57 AM
Has anyone has installed a Mustang / F150 billet fuel door in the front hood to acess the gas filler cap without opening the hood? What needs to be done to get the rim to sit almost flush with the hood? If you just cut a hole is will sit a good 1/4" above the hood.
poorsche914
Oct 26 2009, 11:03 AM
I am also interested in learning what might work best for a project like this.
tat2dphreak
Oct 26 2009, 11:15 AM
if you want it perfectly flush, you could cut a bigger hole in the front trunk and weld in a piece with a smaller diameter on the bottom side, maybe with a spacer too... it will look like crap if the "hood" is open, but look flush when it's closed. I personally don't think it looks bad sticking up a little like the picture, and I think it's more like 1/8"
my advice would be to get a junk hood, and get the technique down where you can do it once, correctly on your car.
tracks914
Oct 26 2009, 11:38 AM
I was going to do that, but for the 3-4 times a year I fuel up the car, I thought I might just as well pop the hood.
tat2dphreak
Oct 26 2009, 11:41 AM
if it turned out 1/2 as nice as iamchappy's car, it would be worth it, but without a paint job to closely follow, I don't think it would be nearly as good.
flipb
Oct 26 2009, 11:44 AM
I don't mean to
, but...
My "hood" latch can be very hard to pull. Is there maintenance for the pull cable to keep it from seizing up?
iamchappy
Oct 26 2009, 01:12 PM
pics, mine sits up just a little bit but it has a beveled edge, i have been considering getting a aluminum finish
one and flat filing it to match the hoods contour.
tat2dphreak
Oct 26 2009, 01:17 PM
exactly the type of piece I was talking about chappy! yours turned out very well!
Geezer914
Oct 26 2009, 01:27 PM
The way the installation looks, I need to cut the hole slightly smaller than the overall diameter, allowing the bevel edge to sit in the hole. This will allow the lip of the filler door to sit as low as posible to the hood. Thanks for the pictures.
Elliot Cannon
Oct 26 2009, 01:47 PM
QUOTE(flipb @ Oct 26 2009, 10:44 AM)
I don't mean to
, but...
Pull the cable out of the housing. Lube it up. Re-install cable. Works fine/lasts a long time.
steveherman
Oct 26 2009, 04:13 PM
QUOTE(iamchappy @ Oct 26 2009, 03:12 PM)
one and flat filling it to match the hoods contour.
i want more info on this.
what parts for the actual filler neck and over flow thingy?
montoya 73 2.0
Oct 27 2009, 12:19 PM
Did you remove the expansion tank for another reason, or was it because of the installation of the door?
iamchappy
Oct 27 2009, 03:46 PM
I just removed it for no other reason than i dont need it.
Dr Evil
Nov 20 2009, 01:08 PM
Bump...I am gonna have Scotty B imitate this on my car. Consider yourself flattered
iamchappy
Nov 20 2009, 01:33 PM
After careful inspection of mine there is no hood contour even the circles i cut out of the hood are pretty darn flat, the beveled edge looks fine as is, so outside of painting the underside of the hood area, i guess I'm done.
rick 918-S
Nov 20 2009, 01:43 PM
If you end up with some rock chips and have the hood repainted I would come down and hammer a step or flange in the hood sheet metal for you.
This would allow a close to flush fit. You could try a flanging tool but the step would be only about 22 GA deep.
You can hand hammer a step pretty deep if you work at it.
rtalich
Nov 20 2009, 01:57 PM
QUOTE(steveherman @ Oct 26 2009, 02:13 PM)
Bumping this question... in order to get rid on the expansion tank.
Dr Evil
Nov 20 2009, 01:59 PM
QUOTE(rick 918-S @ Nov 20 2009, 02:43 PM)
That is how I am gonna have Scotty do it. I want it flush and brushed aluminum
Sexy.
Dr Evil
Nov 20 2009, 02:14 PM
Hey Chap, what dia door did you use?
iamchappy
QUOTE(rtalich @ Nov 20 2009, 01:57 PM)
Just remove it, all the filler stuff is separate from it. i still ran a vapor line back to my
air intake otherwise fumes seem to migrate into the interior.
Dr Evil
Nov 20 2009, 05:06 PM
And the door size ???
iamchappy
Nov 20 2009, 05:30 PM
The hole i cut was 6".
Dr Evil
Nov 20 2009, 05:36 PM
Thanks man. So the door you bought is a 7" dia setup? There are many sizes, but I bet the mustang has a specific size. Searching now.....
r_towle
Nov 20 2009, 06:41 PM
Show off why dont you.....
Rich
iamchappy
Nov 20 2009, 06:53 PM
Ok the size of the outside ring on the door unit is 6.25" my cutout circle piece was less because of the waste material in the cut.
If i was you i would purchase the door first and then measure and cut, or another option is to go to a junk yard and have them cutout a recessed fuel door area from a F150 or Mustang and weld that in or panel weld it to the underside....
Dr Evil
Nov 20 2009, 10:35 PM
Interesting idea. I know I can buy fuel doors in various sizes, but I liked the scale of yours. Not too big, not to small
Dr Evil
Nov 20 2009, 10:58 PM
Here is what I will be using on my dark dark gray car
Sleepin
Nov 20 2009, 11:11 PM
QUOTE(rick 918-S @ Nov 20 2009, 12:43 PM)
I sure wish I could hammer as deep as you Rick!
rick 918-S
Nov 20 2009, 11:45 PM
iamchappy
Jun 23 2010, 08:55 PM
Outside diameter was 6.25".
jim_hoyland
Jun 23 2010, 09:00 PM
QUOTE(Dr Evil @ Nov 20 2009, 09:58 PM)
Can those lids be made to open from inside the car ?
70_914
Jun 25 2010, 12:53 AM
The fuel filler on the original 904 GTS race car was not flush mounted, why should the one on a 914 be?
Represent the racing pedigree with pride!
