swood
Oct 29 2009, 11:38 AM
Looking for:
2.0L crank and rods
Cam and gear - not sure which cam I want yet, most likely for Carbs
Carbs - Weber 40 idf's and stacks
fuel pump
I already have:
1.8 case
96mm stock jugs w/KB's and hastings rings
Mallory dizzy and MSD
Still mulling over what to do...looking to see what materials are out there.
Thanks.
Joe Ricard
Oct 29 2009, 11:45 AM
I have what you need for Cam 86b, lifters, crank, rods.
PM me and we can work out a price shipped.
RiqueMar
Oct 29 2009, 12:46 PM
QUOTE(Joe Ricard @ Oct 29 2009, 10:45 AM)
Might have the weber 40's
Pm me if you like.
Gigamight
Oct 29 2009, 01:37 PM
Sorry for a hijack, but can someone direct a newbie to some info on what is involved in building a 2056? I have searched and searched, and can't find the info. Specifically, info for a newb, considering I don't know a lot about what these parts are from.
Again, sorry for the hijack.
tat2dphreak
Oct 29 2009, 01:47 PM
basically gigamight:
2.0 crank and rods, 96mm pistons/cylinders for a 2.0. and a new cam/lifers(webcam 163 grind is a good one)., and of course new bearings, etc... weber 40s unless you go with Jakes cam grind for using stock djet with a 2056
for actual assembly - jakes video.
in fact, the smart thing, if you want to learn to build one, is to get one of jake's kits...
Gigamight
Oct 29 2009, 03:15 PM
Thanks Wayne. I googled Raby and found a bunch of info.
tat2dphreak
Oct 29 2009, 03:22 PM
Is the 1.8 case better for this build than a 2.0 case?
tat2dphreak
Nov 9 2009, 08:07 AM
nope, a case is a case is a case.
heads are a different story
swood
Nov 29 2009, 05:15 PM
(moving this to the garage)
