Full Version: OT: Cleaning a rag top
jim_hoyland
I'm getting ready to clean a Boxster soft top and would like comments on my plan:
1. The top is in very good, not new though, condition.
2. Going to wash with auto soap and use a nylon brush to loosen the dust
3. Let dry, then spray with scotchguard ( is there another product here I should use ?)
4. Plastic window; fair to good condition. Need suggestions here
Thanks, Jim
computers4kids
QUOTE(jim_hoyland @ Nov 1 2009, 05:39 AM) *
3. Let dry, then spray with scothguard ( is there another product here I should use ?)
Thanks, Jim
Jim...is there something you want to tell us?...or did I just miss the anouncement 'boxster.'
Porsche Rescue
Owners manual for my '04 says water only. Can't remember what it says about brushing. Air dry. Don't use a towel or you will have a coat of lint forever.
Ian Stott
Mild soap rinsed off right away will be okay, buddy of mine has an auto upholstery business and we have done a few boxster tops, original tops are of very good quality material. Don't get aggressive with a brush or you wil have a spot that looks different, also top will tighten up a bit as it dries, that is a good thing, don't let it dry in direct sunlight.
Ian Stott
Moncton
Canada
tommy914
cleaning the top:
I mostly just rinse with the "flat" spray setting on my hose. I use a soft nylon brush occasionally. Don't use a brush with "feathered ends" those will shed on the roof. I dry using a synthetic chamois. I have purchased Raggtop brand cleaner and treatment, but have never applied.
I use a lint removal roller, essential sticky tape on a roll, to clean up towel lint or cat hair.
plastic window:
rinse and wipe clean gently with microfiber towel.
treat with Plexus cleaner and conditioner to clear up the "haze".
I also use the Plexus on the head and tail light plastic lenses.
If you are going to park in the sun a lot, you may want to purchase a cover for just the top. I puchased one on ebay made of Sunbrella material.
here's a current ebay ad from the guy i bought from. http://cgi.ebay.com/ebaymotors/1997-09-POR...sQ5fAccessories
He's using Blockit material now, but I bet you can request whatever you want.
jim_hoyland
Thanks for all the tips everyone.
QUOTE(tommy914 @ Nov 1 2009, 09:37 AM) *
cleaning the top:
plastic window:
EdwardBlume
You live in So Cal. Why is the top up?
burton73
You should use Novus plastic polish on the window. You may need #2 for deeper and #1 for the fine stuff. The 1 is the day to day cleaner and is a great way to remove the static electricity from the plastic.
Novus Polish Kit, Plastic Polish & Scratch Remover
Bob
craig downs
So you did buy that boxster. I hope you keep your 914
jim_hoyland
QUOTE(craig downs @ Nov 1 2009, 12:32 PM) *
Demick
QUOTE(RobW @ Nov 1 2009, 10:31 AM) *
