Robert Blackmon
Nov 1 2009, 07:17 PM
This one has me stumped. The engine stalls momentarily on take off just after releasing the clutch and giving it throttle. I have replaced the centrifigul/points distributer with a vacum advance/electronic ign. I replaced the old 32/36 carb with a brand new 32/36 weber, and adjusted the timing to 27 and 34 deg. BTDC and back again; still, it stalls; has anyone ever seen this before with a carb conversion? Recent suggestions are: weak coil, carb facing the wrong direction, low idle jet too small. I am sure there are no vacuum leaks. The car had this set up when I got it 10 years ago and I am the first one to start the car in 20 years. The previouse owner said it ran fine back then.
BarberDave
Nov 2 2009, 04:54 AM
THat is the nature of the beast!!! Center carbs with long intake runners have a
problem keeping the fuel from puddling in those long intake runners,untill hot.
Get use to it. Or get 40IDF's !!!! Dave
