QUOTE(zymurgist @ Nov 1 2009, 05:34 PM)
Leaking from the body? Are you sure about this? Seems like a high failure rate.
Did you use metric FI hose to connect them? 5/16" is almost 8mm, and you want 7mm hose for the injectors.
not leaking from hose leaking at seam i have seen this happen on other bosch injectors when it is getting colder
