QUOTE(kenshapiro2002 @ Nov 5 2009, 11:01 AM)
Also shows me that the offset of the bracket goes to the outside...still not sure why they did that since the pump can slide in the bracket, right?
Slide in the bracket? The pump needs to be well secured to the bracket. No sliding.
Speaking of that... The CB pump you will be using is smaller then the stock pump, so you will need to use alternate means to keep it secured on the bracket. I used a bigger metal hose clamp.
Zach
