1973 Porsche 914-6 Race Car
Affectionately Known as "The Atomic Creamsicle"
Over $60000 invested in this car over the past 6 years.
Dyno'd at Dawe Motorsport on Mustang Dyno w/ 206 RWHP
Car weighs 1890 lbs w/ 1/4 tank of fuel without driver (runs on 93 octane pump fuel)
One of the quickest and most dependable autocross cars in the East Coast
Car is well known throughout Metro NY PCA / BMWCCA / NASA NE
Raced in Nasa NE in 2009 with 5 poles, 5 wins and 3 track records including Limerock Park (58.4)
All 5 races with in-car video and data aquisition. Link to website below
"Car went out in practice at Watkins Glen last month in the wet on sticker slicks and tapped the armco. Mostly cosmetic fiberglass damage. We were able to repair it to get out next morning,
but had an over rev and bent some valves. Pictures before WGI and after WGI are linked below."
Selling car for $17500 as I am looking to cut my losses and move on to new project waiting
dm914racer@gmail.com or 631-445-3349 Cell
Demetri
Pre WGI http://s193.photobucket.com/albums/z108/dm...0Before%20Sale/
Post WGI http://s193.photobucket.com/albums/z108/dm...6%20For%20Sale/
Video link - http://vimeo.com/dm914/videos
Engine
2.9 liter twin plug
Electromotive Dual Ignition, Crankfire System
7R Case
PMO 46mm carbs
Andial 2.9 litre P&C's 9.8:1 compression
Patterson 3 gallon Oil tank with internal scraper system
-12 and -16 AN Fittings
Web Cam welded and ground cams
Carrera Tensioners
Sachs Sport Clutch
"S" Crankshaft
Fully balanced rotating internals
Lightened and Balanced Flywheel
Relocated remote oil filter housing
Transmission
901 Side Shifter Gearbox
Rennshift Short Shifter
Patrick Motorsport solid shift linkage
Solid Tranny and Engine Mounts
Stock gear ratios
Suspension / Braking / Steering
930 front and rear calipers w/Pagid RS-29 Yellow
Front Slotted Floating Rotors / Rear Cross Drilled Rotors
23mm Master / Steel Braided Lines / Castrol SRF
Wilwood Brake Proportioning Valve
Brake Ducting and Hoses
Fox F&R Externally Adjustable Coilovers w/adjustable spindles
and remote nitrogen reservoirs
ERP 935 style front suspension and crossmember
Reinforced rear trailing arms w/new bearings, hubs
Elephant Racing bushing kit
911 steering rack
Exterior
Full Fiberglass body kit
Rear custom fabricated and adjustable high wing
LED brake lights
Long wheel studs
2 sets of 15x8 Fuchs wheels w/ Hoosier Slicks (1 set are NEW)
1 set of BBS wheels with Brand NEW Hoosier Rains
Exterior battery cut-off switch
Fluidyne 24"x2"x6" front mounted oil cooler
Mocal secondary oil cooler in left front fender
Interior
Extensive 1.5 roll cage w/Nascar Bars
Kirkey Racing Seat
Willans 5 point harness
Adjusted Brake Pedal for proper heel/toe shifting
Schroth Window net and Center net
Full view rear mirror and side mirrors
Odyssey PC-925 race battery
ATL Fuel Cell
Aeroquip steel lines throughout
Fully Fabricated Wiring harness w/fuse block and circuit breakers
Removable Instrument Pod w/quick disconnects
Longacre switch pack with Auto Meter guages
Halotron Fire Extinguisher
