I will list more as I come across them in the future: I think the new lexus hotrod uses rear radiators. The one on the new gt40 might show the most thought in a mid engine application.
The first one is discussing the elise for track use.
http://www.mgf.ultimatemg.com/group2/commo...odification.htm
Electric pump and speed controller:
http://www.mawsolutions.com/html/ewp80.htm
Pressure relief remote thermostat which might be used with a pump that has more volume than needed at times:
http://wiki.seloc.org/a/PRRT
More on a remote bypass thermostat, the suby motor has several bypass circuits for the stock application as the suby is engineered with the idea of keeping all the motor at a more stable temperature to stop heat cycling but it also uses a front motor so the remote bypass might be a better solution for the suby conversion in a mid engine application:
http://web.tiscali.it/elise_s1/index.htm
YOU MIGHT WANT TO START HERE, but remember this is a 500hp motor, new gt40 cooling, this also covers waic and oil cooling, and it's not simple. check out the part about vehicle packaging, 110f ambient needs 7500cfm at 200mph
http://www.roush.com/LinkClick.aspx?fileti...212&mid=932
