I used the 911 sport mounts which are not the same shape as the 914 mount, the outer diameter of the inner metal sleeve for the bolt is much smaller on the 911 unit. The 914 rubber mounts are made to fit within the beveled cup on the metal plate, there is even a locating pin on the mount that fits a recess in the plate (see photo below), the plate prevents the 914 mounting bolt from tearing thought the rubber, if the 914 plate is used there will be a gap of at least a 1/4 inch between the rubber and the plate, that and the difference in size of the inner sleeve could be a problem.
My solution was to use a bar of steel stock, cut to the same size as the 914 plate, size 95 mm by 55 mm, (I used a 1/8 thickness so I did not have to bend the edges of the plate to increase the strength of the part), I drilled a hole in the center, mounted it in place of the 914 plate, it will prevent the bolt from tearing through the rubber if the mount fails, (sorry no photo of solution as it is already in the car).
Mike
ps: I have not clipped reverse gear since installing the new mounts.
old 914 plate
