New Type 4 94mm Nickies with ARP head studs, sold
Type 1 mahles free with set.
Ok next round of the /6 fundraiser
These are part of Mike Muellers "cheap out on pistons" set-up
These are set-up with type 1 mahle "forged" pistons (included) but he was going to use a 78mm crank, the spacers (3/4") and pull out would make it a bad combo.
Head stud package from LN has never been opened, the single a ARP head stud for my 2.7 T4 engine.
So what good are they? Get your stock rods bushed to 22mm pin size for the ultimate street 2.0 engine or some racer could sure use them...
Except for the size of the pin, this piston is the same size and height as a stock 2.0 type 4 piston and it was set up by LN enginering for this piston.
Or I can send them straight to LN Engineering and Charles will make proper set of pistons for a stroker. Bet if you do that he might honor the support he gives, he's a good guy.
You save over sorry sold
Shipping most common areas Canada or US
http://www.lnengineering.com/type4.html
I will trade (or part trade) for /6 parts, I need an oil tank, lines, std/std 2.0 crank, heat exchangers (have line on headers), front mount (no quick six) rebuild items for a six engine, etc.
I also would knock $$ off if you want to collect together some of my parts needs, as it saves me on shipping from several US vendors.
I also have many cool VW bug parts
http://www.thesamba.com/vw/classifieds/sea...name=Mark+Henry
