Targa
Apr 3 2003, 05:23 PM
It appears that I have not one, but two Fuchs with the early mounting surface(like an early Pedrini) that will not mount on my front rotors(75') unless I have them machined. Does anybody else have these or has anyone heard or seen of them?
r_towle
Apr 3 2003, 05:25 PM
I'll takem off your hands,, seeing as they are of no use to you
Targa
Apr 3 2003, 05:32 PM
Actually,
they work just fine in the rear.
Bleyseng
Apr 3 2003, 07:07 PM
Since they came out in 73 with the 2.0L cars I don't see how they could be made for the early rotors.
Geoff
Lawrence
Apr 3 2003, 07:13 PM
What, Geoff?
It's the early wheels (like Pedrini) that don't fit on later rotors. The later rotors have a self-centering ridge that the early wheels won't fit over.
Targa? Are you sure these aren't knock-offs? I checked various references, to include PET, and don't see any reference to pre-73 4 lug Fuchs.
-Rusty
Bleyseng
Apr 3 2003, 10:30 PM
I meant that the 4 bolts Fuchs were made for the later style hubcentric rotors. If he is having a problem fitting them its just cuz they are " tight". They do fit pretty damn tight on some cars.
Geoff
rhodyguy
Apr 4 2003, 07:42 AM
easy test to confirm oem vs cast copy. part # on back, fuch (fox) head on back, dif ridge line on front, less back spacing.
kevin
Lawrence
Apr 4 2003, 12:53 PM
Is that frog in your avatar?
-Rusty
rhodyguy
Apr 4 2003, 06:53 PM
chief(rusty), one morning last fall, i got up and found that frog in a gladiolus in one of my flowerbeds near near my house. i don't think you can see them but there are what appears to be a bunch of silver dots. the frog and the glad were covered in dew. i liked the contrast btween the green and the fusha. my avatar will probably change regularly. when things start to blossom you will understand why i choose "rhodyguy".
kevin
seanery
Apr 4 2003, 07:00 PM
At first I thought maybe your last name was rhoda or something, then I thought you were a roady....and we all know they can't spell....well those of us that know a bunch of em that is....so I figured it must for rhody den drums or something, and then the frog in the flower and voila! Majek!
I don't have any flowers, I need to do something in my back yard.
Gary
Anyone know the offset of the 4 bolt fuchs? I have a set of 4. They're 5 1/2 X 15 and have a 914 part number and the fox head as said above.
Dave_Darling
Apr 5 2003, 07:03 PM
Welcome to the wide, wonderful world of Karmann manufacturing.
Brad Mayeur once told me he had seen a set of Fuchs four-bolt wheels without the hub-centering cutout. Sounds like you have two more.
Alan Caldwell has one of the earliest 1973 2.0 914s around. He ordered it new from Porsche. It's a tailshifter.
There are smaller examples (73 tachs in some early 74 cars, etc.) all over the place.
I would be interested in seeing pics, as well as the part numbers!!
--DD
