Strudelwagon
Nov 13 2009, 09:48 PM
Hey folks,
I peeled back the old carpet and discovered that I have about a 1.5" stress crack in the drivers inner long. Starts at the floor and angles back toward the E-brake at about a 75 degrees.
Question... can I just weld it shut or is there a better way to deal with it?
Your wisdom is appreciated
SW
GeorgeRud
Nov 13 2009, 10:50 PM
If you haven't done so already, I'd remove the outer rocker cover as well and check the entire panel, both inside and out. There are kits out there to reinforce the panels either from the inside or outside.
Search the posts and you should find lots of options.
Bruce Hinds
Nov 13 2009, 11:06 PM
If it is a stress crack, make sure you stop drill each end of the crack. Even before you decide to weld it up.
McMark
Nov 14 2009, 01:01 AM
Weld it up. They
ALL crack there. It's one of the places I check on every car that comes in.
Strudelwagon
Nov 14 2009, 11:36 AM
QUOTE(McMark @ Nov 13 2009, 11:01 PM)
Weld it up. They
Thanks,
I wasn't going to cut through and remove a good outer to access and weld the inner from inside the long as suggested earlier. Mine is rather minor in comparison to your picture.
SW
r_towle
Nov 14 2009, 12:30 PM
I would suggest welding it up, then weld a patch panel over it that extends in all directions 4-6 inches.
Drill out the patch panel every 1 inch in a grid using 1/4 inch holes and plug weld the panel on top.
Grind all the welds , paint and put the carpet back on.
Rich
