Nor.Cal.914
Nov 13 2009, 11:43 PM
My dual carbs are starting to crap out on me and I want to return back to my single Weber progressive carb setup. The single carb that I currently have doesn't work properly so I am in the market for a brand new one. If anyone here has one or has a link to somewhere that carries this carb, please let me know. I would like to get a new one as soon as possible as my mileage is suffering greatly from my duals. Please let me know. Thanks
-Chris
IronHillRestorations
Nov 14 2009, 07:20 AM
No single progressive carb works properly on a type 4 engine, that would be the absolute last choice for 914 carburation.
If your fuel economy is that bad, you need the correct venturi/jet package for your engine.
tat2dphreak
Nov 14 2009, 07:50 AM
aircooled.net has an excellet tech article on proper jetting.
racerbvd
Nov 14 2009, 01:44 PM
Nor.Cal.914
Nov 14 2009, 01:49 PM
QUOTE(9146986 @ Nov 14 2009, 06:20 AM)
Why is that? I believe that my mileage is suffering because of a possible needle and seat problem. But at the same time, it could be more than that and I just don't know. I just wanted to throw a single carb back on for ease of tuning and driveability. Would you suggest a single carb that is NOT progressive? Please let me know. Thanks
-Chris
Nov 14 2009, 07:20 PM
The problem is the intake runners. They are too long and also the fuel puddles in the bottom of the intake. This is why the engine falls on it's face when you floor it at low rpms, too much vacuum loss and the fuel puddling problem.
Yes, it's more expensive to buy the dual set up, but it's best for driveability, fuel economy, and performance.
If you have a stock engine, the fuel injection is best, but I know that can be a major PITA, with old components, etc.
If rebuilding the carbs is over your head, consider sending them to a pro rebuilder and having them put the correct jets and venturis.
What engine is this, and what carbs do you have now?
41ghost
Nov 14 2009, 08:02 PM
check, cip1.com. they have what you are looking for. if you are a stock setup and just want good performance i've herd dual single carb set up works great , certainly better than a progressive, cip's have one that is 40mm , should work great in your case. sets up just like a dual weber only singles.
Mark Henry
Nov 14 2009, 08:33 PM
QUOTE(9146986 @ Nov 14 2009, 08:20 PM)
What brand, number and size are the dual carbs?
41ghost
Nov 14 2009, 10:00 PM
C13-43-4500 - EMPI DUAL 40mm BROSAL (SOLEX) CARBURETOR KIT WITHOUT CHOKE - ALL 17-2000CC BUS & TYPE-4 ENGINES
BarberDave
Nov 15 2009, 07:01 AM
I have had all 3 types on my 1.7 ,, please keep the dual webers . I regularly
preach against the single progressive ,and small duel 1 barrels. P.M. me and
and we will discuss this further. That is if your life and passengers is worth a plug
nickel to you. Dave
