I couldn't resist but take a look at this
16 Piece Rubber Kit includes: My World price
Windshield to top seal $179
Left roll bar vertical seal
Right roll bar vertical seal $36
Left top to sode seal
Right top to side seal $38
Left outer door seal
Right outer door seal $74
Left inner door seal
Right inner door seal $32
Front hood seal Both seals $80
Rear trunk seal Both seals $47
Engine lid to trunk seal $26
Fender to cowl seals (2) $7
Left outer door glass wiper strip
Right outer door glass wiper strip $12
Rear roof seal $40
If you check the math
$571 and you get the bulkhead seals for both trunks.
I'll offer you the same kit at 50% off $1285
To be fair, my seals are not OEM, where the Zim's my be al OEM. I have made some modifications, such as aluminum internals on all. These numbers do include the ends "cut and plugged" on mine.
I do have the lower front targa seal,the lower dash to windshield, the deck lid welting and door handle isolators. These would make it a more complete kit.
I personally would replace the triangle window seals in the doors ( I do not have but they are under developement, and I should have in 6-8 weeks). As well as the front turn signal seals, George at AA has those now. And George's kit is more reasonably priced
I have put together packages for several members in the past, the only problem is that you sometimes you get seals you don't need. If anyone wants a "package" I would be happy to put one together for your specific aplication. I typically can knock a few bucks, but as you can see my margins are not huge.
If I'm out of line on this I'll edit or remove my post, but it just isn't a screaming deal.
