jsayre914
Nov 15 2009, 11:56 AM
On a bosh fuel pump (3 tit) does it cut out if it cannot get fuel?? I realize if it is intermittant it is probably a loose connection, loose or bad relay, loose pin on board, or dirty fuse on board, etc.
i am at work, and i am not so sure i will make it home tonight, i have a few tools, but no electrical stuff with me. i was wondering ....
what would the pump do with good power and a clogged line??
i made it half way to work and the pump cut out 3 times within 1 min, then dead. i pulled over checked the pump and all connections tight. i tried to start it 4-5 times, heard the pump run for 1 sec then dead. crawled under and shook the filtre and banged on the pump. it started but would not idle. i then loosend the clamp holding the pump and turned it upside down. car started and kept strong at high idle but started to choke below 3500 rpm. I risked the drive into work, and made it idling between 3500 and 4500, it would start to cut out and i would downshift jump the rpm and it was ok again.
welcome to my life
jsayre914
Nov 15 2009, 12:56 PM
without tools and time i cannot trouble shoot so much but,
i went out on my lunch break and swapped the relay with the headlight relay changed the fusses on the board and checked pin #13 has good contact as well as the plug on the pump. everthing is go.
fire her up she runs with a little misfire, take it around the block, same thing. pump starts to cut out at full load and or low idle. if i pump the gas a few times i can save it each time.
underthetire
Nov 15 2009, 01:10 PM
ok, not sure I can help but...
If it won't idle and dies at full load i'd check the charging system. You didn't specify what year/injection you have. Without a pressure gauge you really are guessing at a fuel pump IMO. I would check the grounds under the plenum, unplug the air temp sensor on the plenum. The olnly way I can see a plugged line cause this would be a supply line/filter. The other side just goes to the injectors and pressure regulator and back to the T fitting on the pump and back to the tank. It could be the pressure bypass valve on the pump went bad
jsayre914
Nov 15 2009, 03:00 PM
QUOTE(underthetire @ Nov 15 2009, 02:10 PM)
yes you can, thanks
It chokes at any rpm when the pump stops, no lights come on in the dash, and if i goose it a few times it catches again. The fi is a 74 1.8 l-jet.
i have an inline fuel pressure guage, it reads about 30psi, when the car dies it reads zero, i cant see it fluctuate because i am in the drivers seat.
i will change the filtre if and when i get home tonight, that was my original plan. not sure about a bypass valve or where that would be.
thanks for the ideas
jsayre914
Nov 15 2009, 03:06 PM
Hey,
does anybody have a fuel filtre to drop off at the karmic connection tonight?
underthetire
Nov 15 2009, 04:22 PM
Ok, L-jet makes more sense. I think those have a little flapper thingy inside the injection system to turn the pump on if I remember reading correctly. The bypass is the third nipple on the fuel pump.
Cap'n Krusty
Nov 15 2009, 04:24 PM
Clogged filters are rare on our cars. They will NOT cause the pump to stop. It'll keep running until it burns itself up. If this is your L-jet car, check the inlet air boot and any other possible air leaks. The boot is NLA, and has been for years. The airbox will shut off the pump if there's not enough air flow going past the vane. Look at the TWO oil cap gaskets. They should both be intact and functional.
Report back.
The Cap'n
jsayre914
Nov 15 2009, 05:14 PM
QUOTE(Cap'n Krusty @ Nov 15 2009, 05:24 PM)
Report back.
The Cap'n
if the clog will not cause the pump to stop, then i have an electrical problem, or a flapper problem as you said. both oil cap gaskets are brand new, and all vacume lines are brand new. i inspected that huge rubber pipe and washed it good befor putting it back on few weeks ago. Everything is super tight. i have the idle screw all the way in and i can idle just under 1000 smoothly. yesterday.
today is a different story.
i did a different search and found more possibilities. cht wire broken, grounds under plenum came loose, coil has turned around and grounded a wire? i will check these also, before jumping in for my 65mile ride home tonight.
underthetire
Nov 15 2009, 05:54 PM
Sounds like a vacuum leak to me. I don't know of any that would have the idle screw all the way in and idle at 1K.
jsayre914
Nov 15 2009, 05:58 PM
QUOTE(underthetire @ Nov 15 2009, 06:54 PM)
please explain...
i thought this was the norm. if i back the screw one full turn the idle goes up about 500rpm and again if i turn 500 rpm etc. is that not normal??
r_towle
Nov 15 2009, 06:11 PM
QUOTE(jsayre914 @ Nov 15 2009, 06:58 PM)
please explain...
Yes that is normal. its actually perfect...at least the idle screw part is.
When you turn on the key the pump runs for 1.5 seconds, then shuts off.
That is how Djet works. It comes on again when the motor is running.
It sounds to me like you have an elec issue, not a fuel issue.
Ignition wire loose, positive wire to coil loose,
Ignition switch or plug under dash going up into the steering column is loose.
Pull relay board cover...pull all the plugs and volgate regulator...
Reseat all of them.
Clean both positive and negative battery terminals..clean the main power wires (the smaller red ones) that feed the ignition and the accesories)
Make sure your coil is not touching ground.
Check all three wired going to the coil for breaks and shorts.
You need to run through ALL the wires to wiggle them and see what is loose.
I chased an issue for days and it was a loose wire that somehow got inside the distributor and was shorting things out...hard to explain...I rebuilt the distributor to find it.
Rich
jsayre914
Nov 15 2009, 06:20 PM
QUOTE(r_towle @ Nov 15 2009, 07:11 PM)
please explain...
Reseat all of them.
Rich
i am reading this thread like a hawk (since i am jumping into the car at 8pm)
i used to have d-jet and yes it would always run for a sec, but now i have l-jet on a 1.8 and it does not ever run when you turn the key to the on position. i was worried at first but found out that was correct. it only runs when the key is to the start position.
however i have never had this problem before and im not sure how to do the flap test yet.
however... i did go out a few min ago and pulled the fuel filtre out and blew through it backwards as hard as i could and put it back on correctly. then poured a bag of kitty litter under my car. started it up, and did not notice any hesitation at all, but it is still parellel parked, i cant test it out for sure yet.
ericread
Nov 15 2009, 06:21 PM
I recenty had some significant fuel pump issues. So I printed out each of the pages from the following site:
http://members.rennlist.com/pbanders/FPChecklist_frame.htmAfter going completely through the process, I found the fuel pump was, in fact bad.
In your case, I highly advise wiring the battery directly to the fuel pump. This includes both positive and negative wires. If the fuel pump does not run continuously, then the pump is FUBAR. If it does run, then start through each of the pages in the link. You will find your problem.
Eric Read
r_towle
Nov 15 2009, 06:25 PM
QUOTE(jsayre914 @ Nov 15 2009, 07:20 PM)
please explain...
Reseat all of them.
Rich
Ljet pump test.
Pull large rubber hose off the AFM unit so you can stick your finger in the AFM.
Turn key to run position.
Stick finger in AFM unit and open the door (you can see it if you look in the hole)
Pump will run till you let go.
Rich
VaccaRabite
Nov 15 2009, 08:20 PM
You home yet?
Zach
jsayre914
Nov 16 2009, 10:32 AM
QUOTE(r_towle @ Nov 15 2009, 07:25 PM)
Ljet pump test.
Rich
I did not have time to trouble shoot yet, but last night after i made it home
i stopped at the gas station. I opend the air box, and looked up into the lid. i saw the flapper and i took a extra piece of vacume hose and slid it into the afm to hold the flapper open. i jumped into the car started it, and ran back to watch. the pressure guage read solid 30 for about 2min, then it started to stumble. 30....20....30....15.....20....5....0 the car died and i heard the fuel pump cranking away rrrrrrrr untill i pulled the hose and let the flapper shut.
tommorow i will troubleshoot if i can get enough time.
underthetire
Nov 16 2009, 10:35 AM
Could be the sock in the tank. Have you changed it ?
r_towle
Nov 16 2009, 06:07 PM
Its either the fuel pump, or the fuel pressure regulator which is unique to Ljet...its a rising rate fuel pressure regulator.
Rich
jsayre914
Nov 16 2009, 06:17 PM
QUOTE(r_towle @ Nov 16 2009, 07:07 PM)
Rich
tommorow, my plan is to replace the fuel filtre and then run a jumper to the fuel pump from the coil + lead. if it has any cutting or stumbling sounds it is the pump right. if it stumbles but the pump is continues sound. Then i have a clogged sock??
sound like a good approach?
underthetire
Nov 16 2009, 06:20 PM
Not if what Rich says, rising rate regulator. I don't know the Ljets. I think you would need to plug the regulator, not start the car, and watch the fuel pressure for a few minutes.
Rich????
jsayre914
Nov 16 2009, 06:35 PM
QUOTE(underthetire @ Nov 16 2009, 07:20 PM)
Rich????
r_towle
Nov 16 2009, 06:56 PM
The regulator is pretty simple...this happened to me..it was the pump.
The pumps just die after a long life....
If you hold the flapper door open the pump will continue to run...
Car can be not running and the fuel pump will run fine till you let go of the door. No jumper needed.
You could put a fuel pressure gauge in place of the regulator and watch the gauge while the pump runs for 5 minutes straight...see if it looses pressure. Without the regulator expect higher than normal pressure, but it should be fine if all your lines are in good shape.
Rich
r_towle
Nov 16 2009, 07:00 PM
jsayre914
Nov 17 2009, 08:22 AM
i am reading...thanks Rich.
test one. check voltage distributor plugs wires etc. good
test two. mechanical stuff, starts good just wont keep idle for too long.
test three. all hosses are brand new not kinked and secured well.
test four. key on flapper test. Perfect and holds at 37psi no problems
i thought i would have found some problem there???
test four a. crank engine you can hear pump running. good.
this is as far as i got so far.
The website seems to have many broken links. i really wish the links were working, cause i need to do more testing. great site
Millerwelds
Nov 17 2009, 08:36 AM
I recently went through some fuel pump issues on my 2.0 DJet. Turned out the pump would go into bypass mode and circulate fuel right back to the tank bypassing the engine. The pump would always run but I would get no fuel pressure. I ended up taking the pump apart and removing the bypass parts so both the output line and bypass line were wide open and then I plugged the bypass line. Essentially turning it into a two port pump. Has worked great ever since. Without the bypass valve the pressure will drop off as soon as the pump is off as opposed to holding pressure for 20 minutes or so.
Almost everything I read said that the pump would leak once opened up but I was able to use a flat tip to 'crimp' the cap back on and it does not leak. I figured I was going to need a new pump so I might as well try to fix this one first.
Good luck!
jsayre914
Nov 17 2009, 10:53 AM
i just tried the jumper test. + to coil and - to battery neg.
car ran perfect, no hesitating, or choking. i let it run 10min and goosed it now and then. perfect.
so now what does it all mean.
A) it could be a electrical short. dual resistor, wire, connector on relay needs bent?
it could be the fuel pump. acting perfect now, just waiting till i get 1hour from home to act up again, or die forever.
C) (new filter) could have solved the problem??
i will play again little later.
ericread
Nov 17 2009, 11:37 AM
Since you have now determined the pump is good, it's time to look at the control circuits.
Once again, here's a very, very good site to work through the control circuit issues:
r_towle
Nov 17 2009, 07:13 PM
QUOTE(jsayre914 @ Nov 17 2009, 11:53 AM)
Tell me slower.
You jump the coil and the car runs fine?
Rich
r_towle
Nov 17 2009, 07:23 PM
Here is what I would do.
remove the power lead from the positive side of the coil.
Attach a 12 vdc lightbulb, or a test light to the end of that line, and then ground out the other side.
When you turn the key to run, the light will light up.
Now, once you get that working, you can leave the key on and you wont ruin the coil.
Now, I would shake, pull and wiggle the wiring harness in the engine bay that goes from that lead to the relay board...keep at it.
If the light stays lit, back up...its the relay board...tap it...
If that is ok, wiggle the wiring harness that goes from the relay board into the front of the car..its right at the bottom of the firewall...wiggle it.
From there, the next place you can reach it is up under the dash where it comes out of the middle tunnel..wiggle it.
All the way back to the key.
From there, it comes back from the key to the battery.
Remove, clean and check the positive leads on the battery...one might be broken or loose.
Rich
jsayre914
Nov 18 2009, 11:48 AM
i got frusterated last night, looking for the problem. I did not see your post
i will try again
thank you.
(dont be mad) I did drive it to work today. She really runs great. No reason not to drive a bueatiful car on a bueatiful day, because of a loose wire and missing side marker lenses
VaccaRabite
Nov 18 2009, 12:26 PM
If it ran great, maybe you fixed the problem?
Zach
ericread
Nov 18 2009, 12:29 PM
jsayre914
Nov 18 2009, 04:00 PM
QUOTE(Vacca Rabite @ Nov 18 2009, 01:26 PM)
Zach
I meant to say. I hard wired the pump to the coil and that is how it is running perfect. I do not intend to keep it this way
r_towle
Nov 18 2009, 04:43 PM
I am confused.
If this is a fuel pump issue or an ignition issue?
Fuel pump is powered by the "other" relay pack, not the funky looking one for the injectors.
I think that the other relay pack gets its power from via the injector relay pack...cant remember.
Find the 12vdc feed wire for the relay pack near the battery and run a wire right to the battery. It still gets its trigger from the key.
Rich
jsayre914
Nov 18 2009, 05:50 PM
QUOTE(r_towle @ Nov 18 2009, 05:43 PM)
I am confused.
Rich
sorry, i am still learning.
if it was a ignition issue, few days ago when it was stalling out on the highway, the engine was still firing, it was not getting any gas. if it were a ignition issue wouldnt it have died completly. wouldnt it also illuminate the light on the panel??
just asking.
underthetire
Nov 18 2009, 05:53 PM
ooooh, i can answer this one, lost my pump on the bay bridge. Ignition, tach drops right away, bounces around. Fuel pump, still sees RPM, so the tach just kinda keeps up with the motor. Either way, no lights on the dash until the motor actually completely stops.
jsayre914
Nov 18 2009, 05:58 PM
QUOTE(underthetire @ Nov 18 2009, 06:53 PM)
how did you get off the bridge. (i also have those thoughts on really long bridges)??
my last fuel pump went up on the highway, super traffic jam construction. only one lane open and nowhere to pull off. pump died. It totally sucked.
underthetire
Nov 18 2009, 06:02 PM
QUOTE(jsayre914 @ Nov 18 2009, 03:58 PM)
Sort of lucky I was at the first SF exit and was able to push it to the downhill off ramp. Then across a busy street. Thought I was going to stroke out, but I did it. Fixed it, drove it home. No shoulder at all on the bay bridge, in fact I think i'm lucky it didn't fall down on me when I was there.
r_towle
Nov 18 2009, 06:40 PM
So, are you home again?
Do you have a multi meter?
Check the middle connector on the FI relay pack under the battery.
Look for 12VDC when the key is on.
that one, I think, is what feeds the second relay unit its main power.
The second one is where the fuel pump relay resides.
The trigger for the fuel pump relay is activated by the AFM flapper door.
Rich
