QUOTE(type47 @ Nov 15 2009, 06:59 PM)
Interesting thread. I've heard the question if L-jet could be fit on a 2.0 but never D-jet on a 1.8. If you could put 96mm pistons on the 1.8 you'd get 1911cc and the factory D-jet was for a 197X cc so they're so close in displacement that I would question if the MPS would have to be re-calibrated. Instead of drilling out the 2.0 intake runners, just buy 1.8 intake runners as they are the same size already drilled. (and you wouldn't have 5 mounting holes either).
MPS would still need to be calibrated.
Shorter stroke...different vacuum signature and fluxuation. Simple enough to do right, dont guess.
The 1.8 runners wont line up with the 2.0 liter plenum so you need the 2.0 liter runners and get them drilled for the extra bolt holes, or drill and tap the 1.8 head (there is a place for it you can see if its clean) and use the 2.0 liter setup.
With the 2.0 liter airbox, you need to get short plug wires for the drivers side rear plug...it hits the airbox.
Rich
