QUOTE(agentblr @ Nov 16 2009, 03:05 PM)
Those clutch tubes are pretty darn thick IMO. I would grind off the brazing,use the washer method and mig weld it up.
No. The end of the clutch cable is a snug fit going in. Just a little snot inside will cause problems.
The Cap'n has the right idea.
However, you also need to verify that the clutch tube is secure up front.
They usually only fail at the firewall after the front attachments come loose.
