QUOTE(JoshuaSkinner @ Mar 17 2004, 07:40 PM)
Is removing the engine tin really the way to go?
absolutely NOT ...
it's done from underneath. jack the car up. even better if you have a lift.
take the wheels off, that'll give you a bit more room.
the covers are hold down by a tension rod thing, just pry it UP with a screwdriver, it'll pop off.
i actually completely remove that spring thing, it snaps into a hole on each side, it'll be easier to get back on later.
then, use a wrench to loosen the nuts and a very short but wide flat-blade screwdriver to adjust the valves.
i set them all to 0.004 (not the factory specs).
there is a sequence for which valves to do in which order, i forgot, it's in the haynes manual.
if you don't already have one, trust me, you want one right about now.
Andy
