QUOTE(kenshapiro2002 @ Nov 20 2009, 11:51 AM)
You have this all wrong...this is not an argument oh sensitive metric man
22.8 centimeters just sounds bigger than 9 inches.
I know, i'm shallow ...
Anyways, the cleanest install in your case would be to part from your metric ways. There are a few threads about fitting US standard outlets to our tanks. That way, you can add a exact match outlet to the tank.
Do a search here for standard sized fuel tank outlets.
Otherwise,
if you have to adapt from smaller to larger, get a hose that's a close fit for both. Chris's fuel lines come with flared ends, so you get something to clamp to, which helps.
Then there are hoses that taper down.
If the difference in size is too large, that's the better choice rather than trying to stretch/compress a hose on a fitting.
Andy
