Larouex
Nov 20 2009, 09:13 AM
I have searched the forums and I am looking for pictures and descriptions of folks who have done the relocation of the fuel pump to the front of the car.
I have restored the tank, put in SS fuel lines and I am not ready to locate the fuel pump to prevent vapor lock.
TIA,
Larouex
dr914@autoatlanta.com
Nov 20 2009, 09:18 AM
QUOTE(Larouex @ Nov 20 2009, 08:13 AM)
TIA,
Larouex
decent instructions are in the appendix of the "tech tips 700"
Cap'n Krusty
Nov 20 2009, 09:54 AM
"Vapor lock"? Doesn't happen in 914s, even where it gets really hot.
The Cap'n
Spoke
Nov 20 2009, 10:57 AM
QUOTE(Cap'n Krusty @ Nov 20 2009, 10:54 AM)
The Cap'n
I'm at this crossroad too. Tank is out, FI engine is out. Do I locate the pump in front or in the rear? I would like to do the rear just because the wiring is there already.
So is there value in the pump up front or is mounting in the original position ok?
type47
Nov 20 2009, 11:12 AM
Have you had trouble with vapor lock?
Eric_Shea
Nov 20 2009, 11:19 AM
Ummmmmmmm... sure did happen to me, however it was a 6.
championgt1
Nov 20 2009, 12:24 PM
QUOTE(Spoke @ Nov 20 2009, 08:57 AM)
The Cap'n
My pump was up front. I moved it back to the stock location. The way it was wired up front was not right at all. The pump ran constantly with the ignition on.
underthetire
Nov 20 2009, 12:33 PM
I've never had vapor lock. Can't see how it could happen with constant circulation through the pressure regulator. Maybe with low pressure and carbs?
Shade Tree
Nov 20 2009, 12:43 PM
With carbs and low pressure, I was having the issue due to the fact that I'm not very observant and a fuel line was close to a heater hose. In this case, it wouldn't matter where the pump was located. I didn't experience real vapor lock where the car quit running but I could hear the pump get loud when it was getting air bubbles. I re-routed the fuel line so it was at least 6 inches from the heater stuff and routed the heater exhaust away from the bottom of the engine and the problem cleared. I had to cut off the little mushroom shaped deals on the flapper boxes and run hose from there to the fender wells.
Larouex
Nov 20 2009, 02:08 PM
Typical of my fat fingers, I meant "I am ready to NOW locate my pump to the location of 75-76 cars."
Yes I experienced the dreaded high heat and no start up issues this summer. I was asking if folks have done it, what different approaches people have taken and any pictures (like a classic thread)
jmmotorsports
Nov 21 2009, 07:57 AM
QUOTE(Larouex @ Nov 20 2009, 07:13 AM)
TIA,
Larouex
This is how I did the one in my 70.
Jerry
tod914
Nov 21 2009, 09:21 AM
Nice set up Jerry. What filter did you use and what size are the ends?
jmmotorsports
Nov 21 2009, 12:00 PM
The one in my V8.
Jerry
Spoke
Nov 21 2009, 12:35 PM
QUOTE(jmmotorsports @ Nov 21 2009, 08:57 AM)
TIA,
Larouex
Jerry
I like this alot! This could be my installation too. Minimal holes in the bulkhead; Ready access to the pump and filter. Nice!
How has this worked out for you? Anything you would have done differently?
I could see adding a protection cover plate since the fuel pump is in the trunk with the spare tire & junk.
PanelBilly
Nov 21 2009, 01:29 PM
Click to view attachmentI took this picture for the other fuel pump relocation thread from a few days ago, but I might as well post it here. Mine's in the tunnel with the steering rack. This is a '73 and I'm running carbs (some day). Fits in there well and it will be easy to change filters. The filter is between the tank and the pump and I figure I'll add another filter in the engine bay to reduce the problems with crap in the carbs.
