Here is a link to the parts on hand that Carrie made on the first visit. She was pretty thorough.
www.prosalesreps.com/buttercup/parts_on_hand.htm
Also pasted here - it is long.
New Rocker Panels (right and left)
Air Flap 914 559 163 10 1
Steering Cover plate 1
Gas tank rubber pieces 2
Gas Tank expansion piece 1
Early Steel Wheels 5
Springs 2
Clutch Cable w/baby boot 1
New 17mm Master Cylinder 1
Old 17mm Master Cylinder 1
New Accelerator Cable 1
Old Accelerator Cable 1
New Stainless steel brake set 1
New Steering boot 1
Old steering boots (torn) 2
Steering rack 1
New pedal bushing repair kit 1
Fuse panel 1
NEW Engman fuse panel
Relay panel in eng. 1
Clutch/brake rubber cover 1
E-brake handle 1
Used Clutch cable 1
Mikey914 Engine seal kit 1
Mikey914 Engine deck lid seal 1
Heater lever w/cables 1
Rusted out pedal cluster 1
Not rusted out pedal cluster (many parts missing) 1
Rusty rear valance 1
E-brake cable cover (flat metal piece) 1
KYB shocks & coils 2
Rear sail panel trim 2
A pillar piece 1
Washer fluid bottle 1
Sunvisors (L & R w/ center bracket) 1
New Rear Trunk lid rollers (set of 2) 1
New engine-car bolts & nuts 1
Torsion bar front covers (where adjuster screw is) 2
Front windshield pillar 1
New rubber engine mounts to bar 2
Horn 1
Transmission mounts 2
Rear painted over chrome bumper w/tits & rubber 1
Rollbar pad 1
New jack supports 2
Rusted out outer rocker panels 2
Kneepad w/trim 1
Rear valance in good condition 1
Front bumper w/tits, rubber & broken fog covers 1
Seats 2
Headlight motors 2
Headlight assemblies 2
White Headlight surrounds 2 (one is cracked and missing bottom half)
Windshield wiper motor 1
A-arm assembly w/torsion bars & ball joints 1
Front Hoods 2
Rear Hood 1
Engine Lid 1
Rear bumper w/rubber top 1
Front Trunk tire board 1
Backrest w/broken light 1
Passenger Threshold & Carpet Strip (alum.) 1
Sound Deadener (psgr compartment) 1
Door Panels (R & L) 1
Dash assembly w/dash 1
Fresh air box w/motor 1
Kneepad 1
Foam piece 1
Turnsignal assemblies 2
Taillight assemblies 2
Sidemarker assemblies 2
Steering wheel assembly 1
Windshield wiper blades 2
Gauges (Tach, fuel, speedo) 1
Door glass winders (R & L) 1
Door glass & trim (R & L) 1
Aftermarket side mirror 1 (Vitaloni Tornado)
Set of seatbelt assemblies (R &L) 1
Speakers & grilles (R & L) 1
NEW grilles ordered from MORPH
Rear Targa Latches (R &L) 1
Center tray 1
Aftermarket shift knob 1
Shift boot (rubber) 1
Radio 1
Driver door panel 1
Passenger door panel 1
Outer door handles (R &L) 1 is broken
Door locks (R & L) 1
Rear Glass 1
Targa top 1
Front sail panel trim (R & L) 1
Rollbar 2
Rear interior pieces 2
Windshield trim (corner + center?) 1
Driver Threshold & carpet trim (alum.) 1
Front hood springs 2 repainted gloss black
Front Trunk latch 1
Rear Trunk latch 1
Window cranks 2
Plastic door latch surround 2
Inner door handles ( R & L) 1
Seat bottom 1 at upholsterer
Rubber straps for jack 2
Rear Targa top holders (R &L) 1
Top Targa top holders 2
Targa latch cups 2
Engine blower fan 1
Shifter assembly in car 1
Climate control 1
Front Trunk latch on car 1
Rollbar trim 2
Spare thermostat 1
Hold down plate 1
KYB Strut inserts (new) 2
Fuel pump (unknown) 1
Door strap 1
Door striker 1
Plastic 914 emblem 1
Plastic 1.7 emblem 1
E-brake cables 2
