QUOTE(westdesert @ Nov 21 2009, 08:44 PM)
QUOTE(ME733 @ Nov 21 2009, 02:28 PM)
...The GREEN DOT...... is from the chinaman, who while eating , his lunch of ground grass mixed with dirt dribbled on the piston while doing his "Quality Control "job.....So what you SHOULD do is determine If there is a wrist pin offset for yourself..Then decide which way your going to install the pistons...as they relate to the direction of travel up and down and in what rotational direction you want the piston pin offset if you have one.... are the oil control rings ONE piece ?...if so, you want to plan for an insurance policy that covers .YOU ..slamming your Balls in a door jamb. Thats what will be on you mind , shortly, for the stupidity of using them....
ME733,
I am looking for advise not opinions, especially your disgusting juvenile ones. On the other hand if we were both in sixth grade that would be really funny.
Well.....seems like your so uptight about your problem you cannot read the advise contained within the (humorious post I thought).... to help you............so maybe this will help. 1. you must determine if there is a piston pin offset., the piston pin offset is (sometimes/mostly, excepting forged pistons, mostly, ) manufactured into the piston to OFFSET THE WRIST PIN so the piston will not be as noisy , slap the cylinder wall, quite as hard, as the piston approaches TOP DEAD CENTER. 2. I do NOT KNOW for CERTAIN what the GREEN DOT IS FOR ACTUALLY. Usually the piston manufacturer casts into the piston OR stamps into the piston an ARROW. the ARROW normally is to indicate that the piston should be installed...whereby the ARROW should face the flyweel. (this is to ensure that the pin offset is in the proper direction, to minize "piston slap". Your set of high quality pistons do not have any indication as to wrist pin offset. maybe you should call the supplier/manufacturer and ask them what to do. Or YOU could measure the pin offset YOURSELF with a calaper Or you could take the pistons to a engine builder, automotive machine shop, ,have them check pin offset and stamp an ARROW for you. 3. piston rings, I thought my recommendation was clear enough. In my opinion a ONE ,1. piece oil control (the ring at the bottom of the piston), oil control ring is ...no good, junk , cheap way out, and not the highest quality oil control ring design. I recommend a three piece stainless steel oil control ring,s.......don't let this engine assembly project frustrate you too badly .what I used to do when faced with a frustrating issue in engine assy., is to walk away from it awhile ,clear my head, have a beer,and relax a bit. I always found that this technique, allowed for a faster solution to the problem, and made assembly "FUN'. It should not be a miserable experience. YOU will have immense satisfaction when you're done.....hang in there.
