Thanks Jamie, you just dashed my hopes for just ONE job that didn't require hacking and welding.
However, since you've been there, I have to give some credence to your predictions.
Mark, do you have any more info on that pump you're using? It looks just like what I have in mind, but they are not too common an item.
Drive-ability, the engine is a Rover 3.5L, the LT-1's little aluminum brother. It's actually a British reincarnation of the Buick 215 that Jamie is running. I'm building "the mutt", 3.5 block, 4.0 heads and headers (higher compression, better flow), Buick timing cover, valve covers, intake manifold and oil pan, ...... With a boosted cam, higher compression and a few other tweaks, I'm guessing to be in the 200 - 210 hp neighborhood - just enough to get me in trouble.
I've been promising Jamie pics for some time now but every time I think I can actually finish a job worthy of pics, the mutt throws me a slider. However, I think I'm through the hard stuff and hope to have the tranny mounted this weekend and THAT will be an occasion for pics. Stay tuned.
Tom
