QUOTE(Brett W @ Mar 18 2004, 08:48 PM)
If this is a dedicated autocross car you could run some toe out on the rear. What are you running for t-bars?
What are you running for tires and pressure? If you drop the front tire pressure you will be able to rotate the car better.
You need more toe out up front try 1/8. Make sure your sway bar is not binding up, it must not be preloaded. on most lowerd cars it is so you will have to fix that.
What are you running for bushings? What about shocks? remember shocks only help in turn in and corner entry. In a steady state turn they have no effect. If you are running Konis up front go full soft.
If this is indeed a dedicated autocrosser
Get a rear bar.
It's a dedicated AX car.....although I always take it to the streets a few times a week...it's my idea of a mid-afternoon martini.
Here is my current setup: koni sport adjustables all around, a 911S front end (to include the big aluminum S calipers), which frontend I think incorporate 19mm torsion bars - not sure on this spec....turbo tie-rods, bump steer kit, new steering box, 22mm weltmeister swaybar, weltmeister stiffening kit, 200# rear springs, fuch 15X7 F, 15X8 R....hoosier 205 F, 225 R.
It has 1.5 neg camber F, 2. neg R. 1/16" toe-out F, 1/16" toe-in R. Car is 4.25" to ground from doughnut.
I've gone from 40# cold to 30#cold (against hoosier's advice, but with advice from other autocrossers). At the last AX, I ran 8 lbs more in the rear to get it looser to rotate better. I know this is not the ultimate way to balance the car...hence my rear spring questions.
Right now, the car is very neutral. Throttle lift on 60mph off ramps and the rearend kicks out just a little bit - not even enough to need any steering correction. However, the car is STILL not rotating enough in slower AX turns. I know slow speed push is difficult to eliminate, especially in porsches, but it's just not doing it's job. I'm not over-driving it, I'm not "pushing" it thru turns, in fact, I've adjusted my driving style to work with it. This is why I'm asking you guys for some help in getting it to a more optimized balance.
I sure appreciate all your insight.
