QUOTE(Spoke @ Nov 24 2009, 03:20 PM)
If your oil pressure sender is not hooked up, there is a chance that there is not a wire from the relay board to the sender. You will have to run that yourself. It should be easy.
Take another pic of the dizzy and the oil pressure sender should be visible.
Find the right connector contact on your relay board "connector" and run a wire to the sender. Only one wire is needed.
Whether that trace does go across the relay board to the wire harness to the cabin, then over to the warning indicator in the dash, must be determined.
There is a sender and I know it works. Just this car doesnt have the wire. = ) So if I am understanding you correctly, there should be a point on that box, thats missing most of itself, that I can connect a wire to on one end and the other end to the sender and be good to go...
Which one? = )
Eric
