If I understand correctly, the knob on the ECU adjusts mixture. Which direction do you turn the knob to make it run richer or leaner?
I have read that the you should hear 20 clicks from the TPS from closed throttle to open throttle. I hear none - is my TPS faulty?
Thanks.
Bob
